strokin` my 351w
Old Jan 2, 2001 | 09:59 PM
donnie88's Avatar
donnie88
strokin` my 351w
i`ve done the home work now it`s time to asked those who have done the deed.
i thinking a scat crank h beam rods dish pistons...
the goal is a good strong reliable motor.
the truck is an `88 bronco.
next is mass air convertion or rpm performer/750 double pumper?
what about cam choices in the 1500 to 5500 range?
i do some light towing and alot of 4wheeling,but i drive it everyday.
thanks for any help
donnie88
Old Jan 3, 2001 | 08:11 PM
DannyP's Avatar
DannyP
strokin` my 351w
Can't say I've done it, but I lay awake at night thinking about it. Strokerkits.com has about 4 stroker kits for the 351W ranging from 373 to 428 cubes. PAW has a 428 short or long block. I am kinda leery of the reliability of getting 428 cubes out of a 351, but imagine that coupled with a mild roller cam. 500hp easy and all under 5,000rpm.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Jan 4, 2001 | 06:22 AM
chilly460's Avatar
chilly460
strokin` my 351w
[font size="1" color="#FF0000"]LAST EDITED ON 04-Jan-01 AT 07:23 AM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 04-Jan-01 AT 07:23 AM (EST)[/font]
I've also done a ton of research on this motor, I can probably help you out but I have a few questions. First, exactly which stroker kit are you looking at (377, 392, 408, 427?). What heads are you running? What kind of cam do you want (hyd. flat tappet, solid flat tappet, hyd. roller?). Let me know and I'll try to help you out.
Old Jan 4, 2001 | 07:08 PM
donnie88's Avatar
donnie88
strokin` my 351w
the kit i`am thinking 393
cam hyd
heads world products 68cc big valves
induction is still up in the air
Old Jan 4, 2001 | 10:50 PM
hpguy's Avatar
hpguy
strokin` my 351w
As for induction, how about the tallest BLOWER you can find, and 2 Holley 1050cfm Street Demons?? Or for a smaller budget, how about the tallest tunnel ram manifold you can find with the above carbs? Or maybe add a computer and tuned-port injection...?
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Jan 5, 2001 | 04:23 PM
chilly460's Avatar
chilly460
strokin` my 351w
OK, I did a little research and found a couple of cams. I stayed mild on the duration so you'd have plenty of low end torque, even with the extra displacement. A couple things to consider, if you had exhaust side work done the heads you could run a single pattern cam, there are a lot more choices and I saw a few out there that were good. Also, I don't know your budget but a step up to a hyd. roller setup would give you a ton more power without having to go to a radical cam. Anyway, here are the picks I'd go with:
Milder of the two
Crane HMV-272-2 #443942 216/228duration .484/.512lift definitely a stump puller in that motor
Comp XE-268H #31-242-3 224/230dur .509/.512
A step up cam that may require a bit lower gearing or stall converter to be happy, but still plenty of low end
Old Jan 7, 2001 | 07:51 PM
jbhf250's Avatar
jbhf250
strokin` my 351w
794by
Apr 21, 2014 10:25 PM
Donnie801
Modular V10 (6.8l)
Jan 24, 2012 09:11 PM
donniezyea
May 27, 2010 11:06 PM
Donnie
1978 - 1996 Big Bronco
Aug 15, 2004 10:04 AM
