302 EFI Problems!?
Old Jul 26, 2007 | 11:43 PM
Plums72's Avatar
Plums72
Question 302 EFI Problems!?
ok so my truck is running like its rich, i think its the MAP sensor, so how would i go about checking that? also anything else (yes i know that it could be like 30 things) relavent to rough idle, crappy sound and no power?!
this thing is really starting to irritate me!
its lucky i bleed blue!
Old Jul 27, 2007 | 01:28 AM
LxMan1's Avatar
LxMan1
Check and make sure that you have good vacuum to the map sensor at an idle. With little or no vacuum, it will run really rich.
Also, check the fuel pressure regulator. If there is gas in the vacuum line, it is bad.
Old Jul 27, 2007 | 02:37 AM
Plums72's Avatar
Plums72
thanks, i will deff try that!
Old Jul 27, 2007 | 02:43 AM
Plums72's Avatar
Plums72
Umm
you wouldnt happen to have a diagram of what it looks like, i looked it up on google, but can really get a GOOD image of it, especially since I have to check it seeing how my dads out of town!
Old Jul 27, 2007 | 07:31 AM
Conanski's Avatar
Conanski
What makes you think it's the map sensor? Have you pulled the codes? Go here and find out how... http://www.fordfuelinjection.com/?p=13
Old Jul 27, 2007 | 07:33 AM
LxMan1's Avatar
LxMan1
The fuel pressure regulator is round and silver and is on the fuel rail with a single vacuum line coming out of the top. The MAP sensor is black and a little longer than it is tall, maybe 2"x3" and has a vacuum line coming out of the bottom on it. It should be mounted on the firewall.
Old Jul 27, 2007 | 12:54 PM
Mr. M's Avatar
Mr. M
Pull the codes before you try to self diagnose your issue. Don't waste your time buying or testing sensors before you know what your EEC-IV diagnostics tells you.
Or keep on
Good Luck
Mike
Old Jul 27, 2007 | 11:52 PM
Plums72's Avatar
Plums72
well the codes said it was a profile ignition sensor circuit malfuntion, and i have no idear what that means!
secondly i thought it might be the MAP because i have a book on Electronic systems for ford vehicles and what my truck is doing is almost exactly what it describes happens when a MAP sensor has failed
Old Jul 28, 2007 | 03:41 AM
LxMan1's Avatar
LxMan1
I'm thinking that pertains to the pick-up coil in the dizzy, but I'm not 100% sure.
Usually when they start failing, the act real lean like running out of fuel, then die. The after they cool off, they run great for a bit then heat up and repeat the same process again.
Old Jul 28, 2007 | 09:45 AM
Conanski's Avatar
Conanski
The computer knows.. follow it's lead first.
The ignition sensor circuit consists of 2 parts, the Hall Effect sensor inside the distributor that generates a pulse corresponding to cylinder TDC events, and the TFI module that interprets that and generates the PIP(Profile Ignition Pickup) signal and sends it to the computer. See here for a view of both... http://autorepair.about.com/library/images/bl389lib.htm
http://autorepair.about.com/library/illustrations/bl278a-lib.htm
You will have to dismantle the distributor to change the Hall Effect sensor, and it's not likely it has failed if the motor runs at all so start with the TFI module. You can test it as shown in the link, and replace it if it fails. Depending upon the year of your truck, the TFI is either on the side of the distributor or on the fender.
Old Jul 28, 2007 | 03:40 PM
Plums72's Avatar
Plums72
well we bought a new dizzy and my dad relpaced the tfi, but i just dont know, next week ill have to go up to his house when i get some time and just check it out!
Old Aug 9, 2007 | 12:21 AM
Plums72's Avatar
Plums72
possible explanation
ok so i went and checked it out, ok so theres this black cylinder, with wires and stuff going to it, and theres a wire coming from it that connects to a plastic piece which connects to some connectors (name?) and the plastic piece is broke! so what should i do?
Old Aug 9, 2007 | 12:22 AM
Mr. M's Avatar
Mr. M
Posting pictures would be really helpful.
Old Aug 9, 2007 | 12:30 AM
Plums72's Avatar
Plums72
yeah maybe
Old Aug 9, 2007 | 12:35 AM
Plums72's Avatar
Plums72
i dont know what its called though, its a black cylinder on the passenger side of the motor
