Modular V10 (6.8l)
99 V10 throwing code
Old Jul 26, 2007 | 06:42 PM
tlcarrig's Avatar
tlcarrig
Hi gang. I need help. I am getting a P1131 code. Scanner says "Insuff. Switching O2 Bank 1 Sensor 1 Sensor/Lean". The I/M monitors in the scanner also says "Oxygen Sens Mon Inc(incomplete)" and "Oxygen Sens Htr Inc(incomplete). In looking up Ford codes on the internet, that code says to refer to code P1130 for possable causes. In that code section, oil overfill is listed as a probable cause. I just HAD my oil changed by a Pontiac dealership. The oil level is at the top hole on the incorrect dip stick. This tells me that it is overfull. What's the chances that this is the problem? Any help/advice is appreciated. Thanks. OBTW which side is bank 1, driver or passenger?
Old Jul 27, 2007 | 10:56 AM
tlcarrig's Avatar
tlcarrig
Come on guys. 20 looks and no suggestions? I sure do need some input on this. Thanks at least for looking.
Old Jul 27, 2007 | 03:04 PM
tlcarrig's Avatar
tlcarrig
Well, it's not the oil overfill that's causing the problem. Just did a test trip and it's still throwing the same code. I'll start checking the sensor this afternoon. Anybody have a trouble shooting procedure for the sensors?
Old Jul 28, 2007 | 06:09 PM
tlcarrig's Avatar
tlcarrig
Problem solved. Bad O2 sensor on bank 1. Passenger side. Replaced. On the road again.
Old Jul 30, 2007 | 01:37 PM
Big Orn's Avatar
Big Orn
Looks like you got plenty of help, tlcarrig.... heehee....
Sometimes (some of us) have to work for a living and can't chime in on time. Glad you found and it and posted it for the rest of us.
Old Aug 21, 2007 | 11:24 AM
V10_Cougar's Avatar
V10_Cougar
Passenger side is Sensor 1 bank 1. I though it was Bank 1 sensor 2. Does this mean Sensor 2 bank 1 is on the driver side.
Old Aug 22, 2007 | 03:39 PM
tlcarrig's Avatar
tlcarrig
No. Sensor 2 bank 1 is after the cat. Sensor 1 bank 2 is on the driver side. There are only 3 sensors. Two of them are in the Y pipe and one is after the cat. Passenger side is bank 1, driver's side is bank 2. There will not be a bank 2 sensor 2.
hewta
15
Nov 3, 2013 07:45 PM
1999fordpiece
1997 - 2003 F150
Oct 1, 2013 06:08 PM
cplmac
Oct 15, 2011 09:58 PM
gener46
1978 - 1996 Big Bronco
Apr 23, 2006 10:37 PM
psdinalaska
Jan 7, 2005 07:46 PM
