Sponsored by: Real Truck
clunk?
Old Jul 26, 2007 | 03:21 PM
Reave1's Avatar
Reave1
clunk?
When I am in drive and stop at a light and begin to resume driving I am feeling a clunk in the drive train. It only happens when I release the brake and hit the go pedal from a dead stop. It feels like it is coming from the rear of the truck. Not a major clunk, but a clunk. Is this normal, a problem? Any help would be great.
Old Jul 26, 2007 | 03:25 PM
M. Kelly's Avatar
M. Kelly
clunk
This may apply. Not sure
https://www.ford-trucks.com/tsb/full...p?tsb=05-26-10
Old Jul 26, 2007 | 03:26 PM
OZX1's Avatar
OZX1
It's normal (as in a known condition)... Give me a second to find it and I'll post the TSB
OK, here's one issue... grease the splines... https://www.ford-trucks.com/tsb/full...p?tsb=05-26-10
or
The other one I can't find, but there's sometimes a clunk from the transmission as some gears engage... Kinda' bad sounding, but not a bad thing.
Old Jul 26, 2007 | 03:27 PM
blackhat620's Avatar
blackhat620
Yep M. Kelly hit the nail on the head. Slip yoke binding slightly.
Old Jul 26, 2007 | 03:29 PM
Reave1's Avatar
Reave1
That would make complete sense of where it feels like it is coming from. Would that fall under the 100K warranty? Also can anyone else chime in? Just curious if anybody experienced this.
Thanks for the thread it seems like that is it, but I want to be sure.
Old Jul 26, 2007 | 03:30 PM
Reave1's Avatar
Reave1
Sorry for the redundant reply yous guys type faster. Anyway is this serious? or can I take my time getting it fixed?
Old Jul 26, 2007 | 03:31 PM
blackhat620
Reave1,
Not real serious, just anoying. I do not believe this is covered under the 5/100K engine warranty.
Old Jul 26, 2007 | 03:35 PM
Beerstalker's Avatar
Beerstalker
I agree with the others. Not a real serious issue unless you let it go too long. It seems to be a pretty easy fix if you have the tools to do it. If not I can't believe it would cost much to have someone else do (other than a dealer, there hourly rates are usually a bit higher than independant shops).
Old Jul 26, 2007 | 03:40 PM
OZX1's Avatar
OZX1
And it's an easy 1/2 hour fix in the driveway... I have step-by-step instructions if you want them. Just PM me with your email address
Old Aug 29, 2007 | 03:38 PM
badbrad60's Avatar
badbrad60
Did you get this problem fixed? My truck just started doing the same thing. My 02 super Duty did a similar thing and was fixed with the TSB.
I don't see the yoke moving like my 02 did, my 06 seems to have a lot of slop in the pinion gear on the diff. How much slop do you all see when you go from Reverse to forward? Meaning how many degrees does the driveline rotate going from reverse to forward.....Mine seems to move quite a bit, like 2/3 of a turn. Thanks ~!Brad
Old Aug 29, 2007 | 03:49 PM
ryaneverk2's Avatar
ryaneverk2
Would you mind posting them here? That way everyone can benefit from them. As common of an issue as this is, it should help a lot of folks out.
Old Aug 29, 2007 | 03:50 PM
Kep4's Avatar
Kep4
Jäger
www.ford-trucks.com/forums/411503-superduty-clunk-teflon-grease.html
Old Aug 29, 2007 | 04:20 PM
OZX1's Avatar
OZX1
The attached images may be some help, but the text quality may have suffered in the process of shrinking the pics.
Mark the driveshaft and differential alignment. You want to reinstall everything to the proper orientation when you're done.
Remove the four 8mm bolts and drop the driveshaft. Mark the front part of the driveshaft and remove the bands around the boot. The bands remove easily with a little bit of twisting. In hindsight, you don't have to remove the front band. Here is the offending piece. Although the splines look greasy in this picture, there was almost no grease on them. The blue coating is almost worn off, too. I guess Ford put the blue stuff on there so it wouldn't clunk when it was driven off the dealer's lot. Put some bearing grease in the splines. Here is the female part of the slip shaft. I guess Ford probably saved a dollar by not installing a grease fitting here. If I felt better about my drilling and tapping skills I'd install one myself. Thanks Ford!!
Reinstall everything, taking care to make sure everything is lined up as marked. I used cable ties to reattach the boot. Enjoy 'clunk free' driving.
note from ryaneverk2: here's the original source:
http://www.eurekaboy.com/f250/slipjoint.htm
Old Aug 29, 2007 | 04:37 PM
badbrad60's Avatar
badbrad60
Very cool. Thanks fellas, I'll grease it up over the weekend. ~Brad
Old Aug 29, 2007 | 05:32 PM
ryaneverk2's Avatar
ryaneverk2
Not sure if you're aware but that text and those pictures are straight from:
Best to give the original author credit when posting their stuff word for word.
