1978 - 1996 Big Bronco
pop clunk frontend
Old Jul 26, 2007 | 03:02 PM
lattices2's Avatar
lattices2
pop clunk frontend
90 351W EFI
I get a single clunk lots of times when turning sharply(to the left) and it has started to clunks and feels loose on the left front when going over potholes and railroad crossings.
After reading some posts it seems to be the radius arm bushings. I checked and had the front end checked and everything else seems fine.
Also once ive driven it a mile or so and come to a stop , the truck lurches forward with a pop/clunk as it stops. Then when i give it some gas it pops back.
Its been like this for a year getting progressivly worse and is worse it hot weather.
Could the raduis arm bushings be doing this too? Anything else I should check?
thanks
Old Jul 26, 2007 | 03:18 PM
Kemicalburns's Avatar
Kemicalburns
take it to an alignment shop. sounds like bad ball joints or possibly bad front bearings.
Old Jul 26, 2007 | 05:44 PM
lattices2's Avatar
lattices2
Just replaced the bearings and balljoints
Old Jul 26, 2007 | 08:07 PM
flareside_thunder's Avatar
flareside_thunder
I'd says radius arm bushings but...who did the bearings and balljoints?
Old Jul 27, 2007 | 10:24 AM
johnarahill's Avatar
johnarahill
I had the exact same problem, and it's funny because I got all of the same responses. I also had recently replaced ball joints and wheel bearings, and the problem went away at some point, I don't know where it went or why it went, but I know my radius arm bushings are good. The problem just disappeared.
wstone
Feb 23, 2017 12:03 PM
kakashi1578
21
May 6, 2016 02:29 PM
Diesel Submariner
Nov 4, 2012 11:44 PM
RA81222
May 13, 2008 02:22 PM
jmcgardner
Aerostar
Aug 12, 2004 04:20 PM
