Roller Rockers
Old Jul 26, 2007 | 01:50 PM
AJHEATING's Avatar
AJHEATING
Roller Rockers
I Want To Run Roller Rockers On My 300. I Have A Late Sixties 240 Head 3/8 Studs. Just Wandering The Best Way To Go. What Brand? Guide Plates? Screw In Studs? Pushrods? Best Just To Stick With 300 Roller Rockers Or Run Chevy Or Big Ford Rocker? Kind Of Lost With This One. Trying To Find Best Bang For The Buck. Thanks
Old Jul 27, 2007 | 01:15 AM
Col Flashman's Avatar
Col Flashman
Built '65 series 300c.i. (around 312c.i. now) I-6 w/ 300 H.P. @ 4600 rpm & 400 F.T.P. @ 3200 rpm w/ a 9.5-1 C.R.
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
Crane Gold Race Roller Rockers
ARP Main Stud Kit, Rocker Studs,
Fisher International Ballancer
Bore 4.060
Power Hone 4.060
Mild P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser C Intake
Holley 1850 600 CFM
S.S. Borla 2 into 2 Header
8' of 3" tubes attached to Flowmaster 40's
4 Core Desert Radiator mated w/ the Original Radiator Housing
2 1,200 CPU Electric Fans, on @ 180*, off @ 170* mounted diaginally
MSD 6A Eclectronics Package & Coil
Dura spark II Electronic Ignition
cjsteak
Jan 24, 2011 02:32 PM
nextalcupfan
18
Jan 3, 2010 01:40 PM
TxBrokenarrow
23
Mar 2, 2005 09:42 PM
haysr
Mar 23, 2004 11:35 AM
