I own a f-250 with 7.3 turbo with a 5 speed and 4:10 gears
I do a lot of interstate driving and it only wants to run about 65 at 2250 rpms
I was wanting to change the gear ratio so I could run 70 or 75 at 2000 rpms I also skip over first gear and never use it even towing a 26 foot gooseneck hauling hay or tractors.
What gears should I use, 3:23 3:55 3:73???????????????
I have the 3.55 Gears & i'm turning about 2000 at 70 mph. works good for me because I do a lot of long distance driving ( 500 + miles at times ) & getting around 20 mpg.
you really can't have both 70 MPH at 2k and never use 1st gear. if you don't want to use 1st stay with the gears you have. If you want 70 mph at 2k you need 3.55 gears. you might be able to find somebody who wants to swap gears with you.
I have 35" tires and swapped from 4:10 to 3.55 last year. It is a great combo. RPM's are good even at highway speeds. I do have to grab 4th a little quicker on the hills but 4th is a lot more useable. If you have the crappy independant front like I do you may not be able to get 3.73's. The rears are available but not the fronts.
I sure would like to know how people get 20 MPG out of these trucks. Best I have EVER seen is 17 MPG. I think the math is flawed.
i have a 2wd 250 and i average around 16-18 in town and on the highway i get about 18.5 i am pretty sure i have 3.55s i run 2000 rpm at 66 mph. has anybody heard about OD units and what they do to final drive ratios?? i would really like to be able to run about 80 at 2000 but i dont really want to lose any of the gears i have. BTW imho you can start out in 2nd with these gears on anything but uphill and do just fine
you could always look into an overdrive unit as well. I know a few people have them on here and really like them. Would let you keep the low end grunt for towing but bring the rpms down on the highway
I would rather use first gear, that what it is there for is it not I was leaning on a set of 3:55 yukon gears with posi-trac and a set of 3:55 yukon limited in the front
