Which starter do I have?
Old Jul 26, 2007 | 09:31 AM
sasquatch999's Avatar
sasquatch999
What is the difference between a "positive engagement" and "solenoid actuated" starter? I might have to replace mine and, looking at my chiltion's manual, I'd like to know what I'm getting into.
Old Jul 26, 2007 | 12:55 PM
82F100SWB's Avatar
82F100SWB
Your truck should have a positive engagement starter, very easy to change, 15-20 minute job at most, 2 bolts(lower is from the engine side of the bellhousing, upper is from the transmission side, heads will be 1/2" if they're factory bolts, 9/16th if they've been changed) and the bolt(3/8th head) that holds the cable on the tab, and that's it.
Old Jul 26, 2007 | 06:34 PM
sasquatch999
What's the difference between the two ?? I'm curious...
Old Jul 26, 2007 | 06:40 PM
82F100SWB's Avatar
82F100SWB
The positive engagement type used the magnetic field of the motor to engage the starter drive, while the solenoid type uses a solenoid to engage the drive and turn on the power to the motor(has a solenoid mounted directly to the starter)
Old Jul 26, 2007 | 09:09 PM
sasquatch999
Yea, there's no solenoid on my starter....
Mab1957
Oct 21, 2015 01:25 PM
ralbach
Jul 18, 2009 08:24 AM
oldmaninva
General Automotive Discussion
Mar 28, 2006 06:21 PM
royale5
Dec 5, 2005 01:26 PM
gangstakr
Nov 28, 2005 05:33 PM
