That's why you have to add friction modifier to a limited slip, because the clutches need the modifier to grab each other, if not, they'd probably just burn up while rubing together and trying to give traction to the wheel that isn't spinning.
Matt
The friction modifier helps them to slip, not grab.
Limited slip and Posi traction are the same thing.
It's just rights to the name. GM is Posi (or dodge, can't remember) and Limited Slip is fords name.
Packard was the first car to offer an optional Limited Slip differential in 1956. Packard called it Twin Traction. Studebaker used the name, but a different rear axle (a LS Spicer 44) from 1957 thru 1966. When Studebakers were equipped with Twin Traction, a doubled circled TT emblem was attached to the gas lid door on the Hawk models, on the deck lids of other models, and on the tailgates of 1/2 ton pickups.
Limited Slip is a type of differential-it's not Ford's name (is TracLoc the term that Ford uses?). Unless the differential is a torque-biasing type such as a gleason torsen, no torque is transferred to the gripping wheel, there is just a resistance to the speed differential between the slipping wheel and the gripping wheel, provided by clutches or thrust loads on gears, or whatever method is used to provide resistance between the two axle shafts.
A non-limited slip differential is an open differential, meaning that the axle shafts are only linked by the spider gears, which provide no resistance to speed differences between the axle shafts.
so what is a non-limited slip differential? Which is how it is listed on the build sheet for my truck.
Non-limited slip = open.
FWIW.. there are actual differences between a locker, posi and LS diffs.
-A locker does just what it says, locks both sides of the diff together, both wheels get the same amount of torque regardless of traction.
-A posi transfers torque from a slipping wheel to the other gripping wheel through a complicated gear mechanism. Hence the "positive" part of the name. Some traction on both wheels is needed though, 1 wheel in the air and all TQ goes to that wheel.
-A limited slip just limits the amount of slip between the 2 sides of the diff. The preload on the clutch pack determines how much slip will be allowed. Again some traction is needed for this diff to work. On both the LS and Posi diffs, applying the brakes slightly can produce enough load on the diff to get power to the wheel with traction in some extreme cases.
Ford uses LS diffs in it's trucks. GM uses lockers in most of trucks, though clutch type LS diffs are/were available in some. Very few truck manufacturers ever used actual posi diffs, Toyota and Range Rover were 2 that did.
It's probably less expensive to buy it at one of the auto supply stores. I just changed the rear differential in my F250. Two 4 oz. tubes, with the quoted specification, cost about as much as a gallon of the 85W-90 oil. (I have to wonder what the dealer would have charged me for it!) The 85W-90 oil was labeled GL-5 for use with limited slip, and I've read in the past on this forum that the additive is not requited with GL-5 fluid. Don't know if that's true or not, so I put it in anyway. Runs great and QUIETER.
All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary.
Hate to break it to you but there IS such a thing as too much friction modifier. If the diff has too much then the clutches will just slip all the time and your limited-slip functionality has just gone out the window. I used a limited-slip ready gear oil when I changed mine and my rear end didn't make any clicks or noises afterwards so I never used the extra friction modifier. Your LS might be hosed until you get some new gear oil in there. Do a burnout and see if you get 2 tracks
