Modular V10 (6.8l)
Oil Cappacity question
Old Jul 25, 2007 | 09:30 PM
XLnAK's Avatar
XLnAK
Exclamation Oil Cappacity question
My Haynes manual states that all gas engines hold 6qts. But for the last two changes I've removed 6 and almost 3/4qrts . My rig is an 04 crew 4x4 w/oil cooler above the filter. I fill the filter before install. I let her drain from pan and cooler real good. Even just over 6 and a 1/2 seems odd. But if its normal I need Your help to know. Also - I've checked oil level in three or more seamingly level areas and dont seem to be over filling?
Old Jul 25, 2007 | 10:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
I usually put in 6.5 qts. It takes it a bit above midway on the hashmarks.
You can run it with 6 qts no problem but it will take a bit more...as you've seen.
Old Jul 25, 2007 | 10:19 PM
XLnAK's Avatar
XLnAK
Thanks Monsta, this must be what I'm seeing. I do take it to the top of the hash marks, just below the upper hole in the stick.
Old Jul 26, 2007 | 05:54 PM
Geneoh's Avatar
Geneoh
I put 7qt's in my 2007 V10
takes it to the top of the full mark, works for me.
Gene
Old Jul 26, 2007 | 06:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Ford says for the 2-valver to put in 6 qts, and as long as it's between the marks, do NOT add more.
For the 3-valvers, it's 7 qts.
I used to get the occasional blue-puff on cold startup, but it's much less common, almost non-existant, now that I stopped putting 6.5 qts in my '01
