heads
Old Feb 15, 2001 | 04:57 PM
jmccary's Avatar
jmccary
heads
Does anyone know what kind of heads would be a good performance upgrade to a 351w and keep it a daily driver? Assuming that you plan to upgrade the carb, exhaust system, cam, etc. Would simply polishing the stock heads and using new springs, lifters, etc. provide a significant increase in performance (just something noticable off road and towing) or do you need more radical modifications?
Any advice/input/experiences woudl be appreciated.
thanks.
jason
Old Feb 16, 2001 | 07:46 AM
DeenHylton's Avatar
DeenHylton
heads
>and keep it a daily
>driver?
>system, cam, etc.
If your going to do ALL the above then I would say don't waste your money unless you increase your valve sizes and open up the exhaust side of the head. Your best bet would be to probably purchase a set of "World Performance" cast iron heads for around $800. a set. They are advertized as good for up to 100 HP increase.
Would simply
>performance
I would say "no" to "significant". But if you stay with a small vacuum operated secondary carb (600-650 CFM) and a "small" cam change (195-204 duration @ .050) your stock heads will be fine.
>thanks.
>jason
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Feb 16, 2001 | 03:14 PM
lanero's Avatar
lanero
heads
This article is a comparison of small block heads. Check it out.
[http://www.fordmuscle.com/archives/2000/05/heads/index.shtml]
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old Feb 16, 2001 | 05:04 PM
StrangeRanger's Avatar
StrangeRanger
heads
Hit the swap meets and find a set of iron GT-40 heads. there's lots of them out there as people have switched their Mustangs over to aluminum. Look for 3 lines on the end of the casting. If you pay $600 you'll pay too much.
Old Feb 18, 2001 | 05:31 AM
newtobroncos's Avatar
newtobroncos
heads
nonricer
2009 - 2014 F150
Jan 11, 2014 01:38 AM
lilpro
Apr 24, 2013 08:53 PM
martinez53
Mar 11, 2011 08:50 PM
mustangbiggie
Engine Swaps
Jun 22, 2004 11:09 PM
avomcd
Aug 22, 2002 01:12 PM
