Buzzing blinker/brake relay
Old 07-25-2007, 07:50 PM
bow4elk's Avatar
bow4elk
bow4elk is offline
Somebody help. 2003 F-250 Powerstroke 7.3 6 speed
Have an irritating buzzing sound and feel in the relay for the blinkers/brake when the ignition is turned on. I replaced the relay and still getting the buzz. Blinkers still work and the buzz stops when I turn the blinker on or when I hit the brakes. Anybody please.
Old 07-25-2007, 10:10 PM
Benny2002's Avatar
Benny2002
Benny2002 is offline
Its the turn signal arm, or the harness connecting the arm to the relays. ive heard sometimes its too short from the factory and partially unpluggs (tilt steering), take the colum covers off and see if its plugged in all the way at the arm and follow the wires down the colum and make sure its all plugged in tight, if its not then you probably have to buy a new arm, i think it comes with new harness? Mine did it too but i was able to wiggle the wiring around after taking it apart and made it stop,
Old 07-25-2007, 10:30 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
I had this same issue with a low battery charge just today. I cleaned and charged the batts and the buzzing went away.
Old 07-25-2007, 10:57 PM
bow4elk's Avatar
bow4elk
bow4elk is offline
Thanks Gentlemen. Late tonight so will look into it tomorrow. Will keep you informed. Thought it was possible low voltage coming in but never thought about too short of wiring. Thanks again
tufftruck
11-10-2016 12:54 PM
V10man
1999 to 2016 Super Duty
08-01-2016 09:50 PM
miihere24
44
01-14-2016 12:32 PM
heatherc
1997-2006 Expedition & Navigator
12-19-2012 08:59 PM
stroke-of-luck00
11-02-2008 08:58 AM
Quick Reply: Buzzing blinker/brake relay
