Transmission problem...1994 4.9L E4OD
Old Jul 29, 2007 | 12:15 PM
Webdoc58's Avatar
Webdoc58
Psom?
You guys may have just hit on something that might solve my problem. When mine starts slipping, jumping, etc. the cruise control stops working. It won't reengage until everythings back to normal. Then if it starts misbehaving again, the cruise drops right back out. Had this happen several times on the interstate. Speedo needle seems fine, but it keeps throwing a 452 code in memory. 452- VSS voltage too low. Have replaced the VSS and hasn't helped. Still getting the same code. From what I understand the PSOM sends it's speed signal from the VSS on to the PCM. Could this thing be getting it's signal from the VSS, still running the speedo, and not sending it's output on down the line? Anyone seen this before? Where do you get a PSOM? Don't they hold the calibration for your tire size as well as your mileage for the odometer? Wouldn't a new one have to be recalibrated?
Farmer_Jack_13
Oct 24, 2016 12:26 PM
anotherexpedition
Aug 8, 2012 03:10 PM
xcaliber1972
22
Apr 18, 2011 01:52 PM
SupaDups
Jul 18, 2007 10:03 PM
Chevy_Monza
Jun 11, 2004 06:28 PM
