a/c clarification - max vs norm
Old Jul 25, 2007 | 01:00 PM
quicklook2's Avatar
quicklook2
this is clear as mud.
we need a poll.
or a test and a tech write up.
Old Jul 25, 2007 | 01:03 PM
tomtoc's Avatar
tomtoc
i figured it'd be a simple answer. i was really just curious what was "better" for most of the components.
MAX w/ fan on 1 or
NORM w/ fan on 2
17 posts later...who knows
Old Jul 25, 2007 | 01:20 PM
jas88's Avatar
jas88
If there is any difference, I bet you would be hard-pressed to measure it.
Old Jul 25, 2007 | 01:25 PM
subford's Avatar
subford
MAX w/ fan on 1 or
NORM w/ fan on 2
It is simple, Max on 1 is better for all components.
It sounds like some of the posters do understand how the A/C system and DC motors work.
Old Jul 25, 2007 | 01:31 PM
subford's Avatar
subford
It is very measurable, put your amp probe on the ground wire from the fan motor and watch the difference between MAX and NOR.
Watch your high side gauge and run the A/C with the truck pulled down on MAX and then turn it to NOR and watch the pressure go up. And pressure = MPG.
Old Jul 25, 2007 | 02:43 PM
jas88's Avatar
jas88
OK, let me be clearer - I bet you would be hard-pressed to measure the difference in terms of wear on your truck and mpg.
I disagree with this. The high-side pressure is much more effected by the speed of air flowing over the condensor, or ambient temp, than by what is going on over on the low-side.
Old Jul 25, 2007 | 02:59 PM
shotime91's Avatar
shotime91
one word -wow!-
Old Jul 25, 2007 | 03:54 PM
gray91's Avatar
gray91
subford and dean88 have it right. In other brand vehicles they have a separate vent control called "fresh" and "recirc". MAX is better overall because you're re-cooling the air while "norm" can be much harder on the refrigeration system itself, especially on a very hot and humid day, pulling in that air and cooling it. But they do say in the manuals to start off in NORM because after being closed up the interior can be a lot hotter than the outside. The louder noise on MAX (and "recirc" for those who have it) is because the blower is drawing air from right under the dash.
Old Jul 25, 2007 | 07:56 PM
netscaner's Avatar
netscaner
Actually NORM should load the blower slightly more because you are pressurizing the cabin.................unless you have too many rust holes.
Old Jul 25, 2007 | 08:12 PM
handyman43358's Avatar
handyman43358
Ohhh the classic Normal/Max AC arguement. I can't tell you how many people have said "MAX means its using more fuel and blah blah blah..." and then I slap them.
When you put a Ford on MAX A/C, that is just like hopping into a Chevy, hitting the A/C button, and then hitting the Recirculate buttom to get "Max A/C." Ford, of course, Is simpler!.
The easiest way I found to explain it, is that in Normal mode, it is trying to cool hot air from outside, while MAX takes the already chilled cabin air, and makes it colder. It may not be right, but it's close enough, and people still don't believe you!
Old Jul 25, 2007 | 08:16 PM
subford's Avatar
subford
Yes that is why it is quieter and not as much air comes out and amps go up on the motor.
Old Jul 25, 2007 | 08:22 PM
pfogle's Avatar
pfogle
The A/C system is pretty simple in these trucks. There are two baffles in the heater box, one changes the air from over the A/C coils to over the heater core. The other controls the OUTSIDE air intake. When you put the control in the MAX A/C position it closes the OUTSIDE AIR INTAKE and forces the system to recirculate what's already in the cab. The best way to use you're A/C system is to roll the windows down half way and turn it to NORM for the first few minutes. This will force the HOT air out of the cab and the cooler air from outside is less of a strain on the system at this point. Once the air in the cab is noticeably cooler switch it over the MAX setting, which will keep the system from working as hard. The reason it sounds like the blower is working harder is that you now have a small restriction in the intake causing a higher air velocity in the ductwork, AND you're now hearing the intake side of the blower as well as the output.
Old Jul 25, 2007 | 09:02 PM
  #28
tomtoc's Avatar
tomtoc
short answer if i understand correctly:
MAX is easier on components. use NORM to get fresh, cooler air into the cab when the cab is really hot with the windows cracked then switch over to MAX. can we all agree?
thanks again for what i thought was going to be a simple question with a simple answer.
Old Jul 25, 2007 | 09:04 PM
  #29
handyman43358
Haha don't worry about it tomtoc. At least we all know now.
Old Jul 25, 2007 | 09:09 PM
  #30
pfogle's Avatar
pfogle
Yes Tomtoc that is correct. That will be the easiest on the system. It works well too, that's the way I used the A/C in my '92 E150 and it still worked well at almost 200k miles.
