Modular V10 (6.8l)
Towing in O/D
Old Jul 25, 2007 | 08:10 AM
tomsen5's Avatar
tomsen5
Question Towing in O/D
Good Morning. I recently bought a 2002 F250 CC 4x4 V10,I pull a 29ft. Jayco travel trailer with an approx loaded weight of 7000-7500lbs. Has anyone out there towed in O/D pulling this kind of weight??? I would never dream of it in my old Super Crew F150 5.4 3.55. Thanks, Steve
Old Jul 25, 2007 | 08:35 AM
benr0's Avatar
benr0
I pulled a Jayco 32BHS 2001, F250 CC - 3.73 gears.
Pulled in OD on the flats, depending on winds, hills I did spend alot of time with OD off.
Old Jul 25, 2007 | 10:06 AM
tomsen5's Avatar
tomsen5
BenrO, What kind of mileage do you get towing your 32BHS??
Old Jul 25, 2007 | 10:54 AM
hydro_37's Avatar
hydro_37
You can pull in O/D without a problem. If the transmission starts to downshift alot then I would definately take O/D off.
Old Jul 25, 2007 | 01:56 PM
dkf's Avatar
dkf
I turn off the OD at the bottom of the hills and bring the rpm up for the climb. If the load is too much the tranny will shift out of OD into 2nd or 3rd when needed. I know my truck and I can tell when it needs to shift so I use OD accordingly.
Old Jul 25, 2007 | 02:40 PM
MarkMoore's Avatar
MarkMoore
As long as it is not "hunting" gears (going in OD, then to 3rd and back to OD) every few minutes, I just leave it alone and let it do it's thing.
I just did a 1800 mile trip from NC to OH and PA, then back home. Averaged 7.4 in the mountains and 8.6 on the flats. My TT weighs in at about 10k.
Old Jul 25, 2007 | 02:59 PM
wfof250v10's Avatar
wfof250v10
I only use OD on the flats when I know the trannie isn't going to be shifting back and forth between gears. I know 3 people with Fords, 2 PSD and 1 V10 that used OD all the time and burned their trannies out at $3,500+.
Old Jul 25, 2007 | 05:06 PM
rclarke's Avatar
rclarke
Tow in the tallest gear that the torque converter will stay locked. If the torque converter unlocks the heat will build up immediately. Get to know your truck and downshift the transmission manually when needed.
Old Jul 25, 2007 | 09:16 PM
Navistar's Avatar
Navistar
Also consider a Banks TransCommand or similiar system built into better programers like the predator. My TransCommand eliminated "hunting" as MarkMoore said completely while towing.
lionsteve
Jul 28, 2014 01:10 PM
MIKE 04 GT
1997 - 2003 F150
17
Jun 8, 2009 04:16 PM
sredlihcm
Jan 18, 2008 07:09 PM
tomsen5
Sep 7, 2007 07:58 AM
2000psd
Sep 6, 2004 08:53 PM
