Help me out on engine Build up Please?
Old Mar 4, 2001 | 06:30 PM
billyb's Avatar
billyb
Old Mar 14, 2001 | 05:46 PM
killer4x4's Avatar
killer4x4
Ok I dont reall know whats best. But this is gonna be a High Perf rebuild. Not Limited to waht I can spend on it. I'll say what I have decided on and asked your opinion on what to get.
-Probly geting some earlier heads 69 or 70 with screw in studs instead of pedestal type.
-The block is a '71
-Heads are '73
-Probly gonna go with Edelbrock 750 Man. Carb
-Either TRW or KB Pistons dont know which..Looking for about 9.5:1 compression.
-Dont know which cam
-Crankshaft PAW
-All the bearings, dont know which is best
-Rods, Also dont know which is best
-Intake Manifold- Performer RPM, Or Performer
-Timing Chain, True Roller
What else did I miss?
1985 "Cowboy Cadillac" Ford F-250 4x4, Granny 4-speed, 4:10 Gears, 460 with Holley 750cfm 4-barrel Carb, Custom Painted Block (Ford Dark Blue), Rebuilt Transfer Case, BFG Trac-Edges, Tachometer, Kenwood CD Player and Pioneer Speakers, 27" cherry bombs dualed out each side with 2 1/2 inch pipe, NAPA Premium Clutch, NAPA Premium timing Chain, Gooseneck Ball, Hitch Reciever, Whistler 400 radar detector!
"When in Doubt GAS it"
Old Mar 14, 2001 | 06:19 PM
Nitro's Avatar
Nitro
All the specs sound good, but one problem, what size of engine is this?? You never mentioned that.
Nitro
Old Mar 14, 2001 | 07:23 PM
killer4x4's Avatar
killer4x4
Its a 460.
Old Mar 14, 2001 | 08:27 PM
DannyP's Avatar
DannyP
If you ain't in a real big hurry, you should watch EBAY for a pair of Edelbrock or other aluminum heads. You can pick up a pretty good bargain there at times. I wish I had thought of that and maybe saved a few bucks.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Mar 14, 2001 | 08:59 PM
killer4x4's Avatar
killer4x4
Hi Danny,
When you converted from the I6 what did you have to change? The wiring harness? how did it all match up? did you do away with the computer and what not?
I am look for a set of earlier heads like the 69 or 70's I dont want to go into aluminum just yet. Also what about adding some CJ heads off a 429?
Old Mar 15, 2001 | 10:35 AM
DannyP's Avatar
DannyP
When I did my swap to a 351W and carb, I just isolated the few wires I needed from the 1" thick wiring harness and clipped off the remainder. It was a big job going from the EFI I6 to a carbed 351W-had to change just about everything but the bellhousing. I am not an expert on Big Blocks, heck, this is the first Ford I ever owned. I do believe that the Edelbrock heads breathed alot of life into my 351. I drove a 96 F-350 with a 351W in it and it was sick compared to mine.
DannyP
Old Mar 15, 2001 | 11:26 AM
blacklightningf150's Avatar
blacklightningf150
Just wanted to say be carefull of what you buy from "ebay" as there are people selling junk saying its "new" or like "new" i had a friend buy a Deck for his car and when he got it it didnt work turns out it was a deck from the factory that wouldnt work when tested so they through it out "someone" picked it up and others and are selling them to people, oh and he was out his $400 and had to still pay to have the Deck fixed so just be carefull most if not all items have a no return policy
2000 F150 Extended Cab 4x4 Sport, all Black
Head light covers
Tail light covers
"FordmotorSports" sticker in rear window
Stereo upgrade soon need some "thump"
Old Mar 16, 2001 | 11:05 PM
karljay's Avatar
karljay
Forget about machined parts from PAW. Go with a good speed shop that will properly setup and grind the crank. I bought a PAW rebuild kit and the rods were not resized properly. I ended up having the bottom end redone by a professional speed shop.
Also, when I was doing the rebuild myself, I asked the shop that was doing the balancing if they could finish off the build and give a warrenty on it, the answer was no. Most good shops won't stand behind someone elses machine work. PAW as fine for ready made parts (intakes, oil pans...) but I would never buy machined parts from them again, the quality was poor.
I'm not the only one that has had this problem with PAW, I only wish I had checked them out before spending all the money.
