Roof Racks - Baskets
Old Jul 24, 2007 | 10:57 PM
Desert-Rat's Avatar
Desert-Rat
Anyone out there construct their own version of a roof rack or basket? I thought about purchasing one of those full size contractor types as a shell and welding a basket and floor on to it...
Old Jul 25, 2007 | 06:30 PM
rebocardo's Avatar
rebocardo
I have welded my own up in the past.
The store ones are usually aluminum. For what they charge ($400+) I think you would be better off making your own. I make a lot of things from steel (spring) bed frames including trailers. I usually get the frames for free on CL. Only drawback is trying to drill the frames as most store bought drill bits are good for 2-3 holes if that before they are totally dull even with liberal oil use.
Old Aug 2, 2007 | 12:54 PM
Frat-man-du's Avatar
Frat-man-du
Depends on how much weight. my factory (MARK III) aluminum rack will only hold about 60lbs and that is pushing it - it really sucks. If I ever change out I will use steel or of if the wife lets me spend $$$ I will go the stainless route. The store ones I have seen are not much better - either do one up yourself or any welding shop can do it a lot cheaper than $400.
Old Aug 2, 2007 | 03:34 PM
Randy8876's Avatar
Randy8876
I might buy a custom made rack from this guy:
http://www.blackoutaz.com/racks.htm
The cost is up there, but I want one that is 5'x9' with light bars at each end. I might check craigslist to see if any welders on there could make it for cheaper locally before making the purchase.
Old Aug 2, 2007 | 06:47 PM
Desert-Rat's Avatar
Desert-Rat
Awesome find! Exactly what I am looking for. I think I will contact them and get some prices, then do like you said and check a local welder and compare.
Old Aug 3, 2007 | 02:36 PM
packlet's Avatar
packlet
i found mine in a junkyard (bolted to the roof of another van) for ~$50. It was originally for a pickup. I sawed off all the mounting feet and re-mounted it on Con-Ferr gutter-clamp brackets (~$150 for 10 at the time, good for 200lbs each) , then slapped a sheet of 3/4" 5x9' plywood up there. I've carried a LOT of stuff up there. Built myself a ladder out of wood on the side to get up there, since i have a Tommy lift on the back. After 6 years, the ladder is getting a little rickety and i should replace the plywood, but still serviceable...
https://www.ford-trucks.com/user_gal...=24090&width=0
Old Aug 3, 2007 | 10:14 PM
Club Wagon's Avatar
Club Wagon
Was impressed by a custom made "roof rack" that kind of reminded me of the old LandRover desert double roof, at a racing event, where the owners sat ontop for a good view. It was made from another Econoline roof panel cut out of a wreck & attached about an inch over the existing roof with enough reinforcements & foam insulation that it could support more weight than you'd ever plan to put up there or want to drive with. Folding chairs nested right in the gullies & they had a low railing like many boats for safety grab & tying down freight. Forget how the edge was finished, but remember it looking good.
Old Aug 4, 2007 | 05:43 PM
Desert-Rat's Avatar
Desert-Rat
I noticed yours is attached to the rain gutters. How much weight can it hold?
