Well Im nearing the end of getting my 460 swap running...I was able to hook most of the hoses, lines, ext. with the help of looking around the forums, and Milions fte sight...thanks for having that great info milion lol....but anyway Im stumped of the last 2-3 hoses and where they hook up...When I took my 351M out in my autoshop class my bro helped me and I couldnt keep track of everything that was disconnected and looking back I should have tagged everything...but anywho Heres the pics of the hoses that I need to hook up...
The fist two are comming out of what I believe is the ref canister...
Shot with Digimax A503 / Kenox D503 at 2007-07-24
The other one is going to some kind of three way connector that goes to the firewall and then goes to a canister on the drivers side over the wheel well (in the engine compartment)
You can see the end of the hoses in the foreground of the pic....
Btw thanks for all the help you guys have been.
Yea Ill get pics put up tomorrow...its to dark outside right now....the vacuum res. just has 3 lines comming out (already hooked the 1st one up) but the other two are just straight out of the res.
as for the other line ill take a couple pics of where the line leads to and where the 3 way connects too...
I believe i do have 2...theres one in the engine compartment and the other is bolted to the frame under the passenger side.
heres the other pics where the other hose goes too.
fisrt pic is where the 3way connector goes into the firewall.
Shot with Digimax A503 / Kenox D503 at 2007-07-25
the and the other side goes to this...
I drew some arrows to where the line goes into (the circled thing) and where one of the lines go into the firewall...if this doesnt help i'll get other pics
o yea its called a fuel vapor canister...One line already hooked to the carb and the other two im not sure of...heres a better pic of it.
And heres a pic of the way conector that was circled in my previous post.
