460 redline
Old Oct 20, 2000 | 12:06 AM
schtuffy's Avatar
schtuffy
460 redline
Hello, can anyone tell me what the redline would be on a stock '77 460, and what do I have to do bump it up to about 5500rpm for more horsepower.
Also, can you tell me roughly what it would cost to rebuild it so that it cranks out 350-400 horsepower? Thanks
Old Oct 20, 2000 | 06:53 AM
chilly460's Avatar
chilly460
460 redline
Your basic roadblocks in that motor are intake, cam, and compression. Put a decent 9.0:1 piston in it, run an Edelbrock Performer intake with 750 vacuum secondary carb., and any kind of decent cam with roughly .500 lift and 215 degrees of duration and you'll hit those numbers. One note, you don't have to wind a 460 to 5500 to hit the hp numbers you're looking at. I'd think you'll be in the $1500-$2000 range for a rebuild depending how many parts you choose to replace, if you recondition the valve seats and guides, use new valves, get it balanced, etc.
Old Mar 5, 2001 | 11:22 PM
proud owner's Avatar
proud owner
460 redline
That engine prob redlines at around 5000... I wouldnt push it much past that.
I built a 460... Pulled a junkyard motor, and invested the following:
Mild Cam (1500-4500 rpm)
Good ignition system
Speed Pro Piston Rings
Gasket Set
Bearing Set
Water Pump
3 wks of labor (porting/polishing/valves/etc.)
Engine now kicks 384 hp, 477 ft. lbs. torque at the rear wheels..
I only spent a TOTAL of 850 bucks..including the block..
Maybe I got lucky! Good Luck.
Old Mar 25, 2001 | 06:20 PM
79supercab4x4's Avatar
79supercab4x4
460 redline
proud owner...what year is your 460? what would you estimate your CR to be? those are pretty good HP #'s for a mostly stock sounding engine. what kind of ignition system are you using and how much do you think it helped. also, are you using the stock intake, and what kind of carb are you using?
ps...sorry to bother you but im slowly building a big block and am curious about some stuff
Old Mar 29, 2001 | 03:17 PM
tuff1's Avatar
tuff1
460 redline
Just remember that that engine is made for torque, not winding up like a small block. That said, with enough money you can do anything.
The only good chevy is a dead chevy
Old Mar 29, 2001 | 06:05 PM
karljay's Avatar
karljay
460 redline
takehikes
Aug 8, 2015 08:49 PM
dc-tennessee
Sep 18, 2010 01:32 PM
ErrorS
Feb 15, 2008 05:55 AM
TallPaul
Oil & Lubrication
19
Aug 12, 2004 07:44 AM
TallPaul
Jun 25, 2004 08:30 AM
