Bronco II help
Old Mar 31, 2001 | 10:47 AM
77_F150_4x4's Avatar
77_F150_4x4
Bronco II help
I just bought my 85 Bronco II auto 2.9 V-6 4x4 it runs good but, the little breather is blowing oil I have oil in my air cleaner box and still dont know why the air filter that goes in the slot is soaked with oil. Any ideas why? help i start driving this thing monday.
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
85 Bronco II
"Baby Beast"
Old Mar 31, 2001 | 03:52 PM
Bill_Beyer's Avatar
Bill_Beyer
Bronco II help
First thing to do is chack your PCV system. Make sure it's working correctly. How many miles are on the motor?
Old Mar 31, 2001 | 07:56 PM
77_F150_4x4
Bronco II help
The motor was just rebuilt before I bought it i guess it runs good except for the tranny needs flushed out. I will check the PVC system out tommarow.
Curtis
77_F150_4x4 aka
"The BeAsT"
85 Bronco II aka
"Baby Beast"
Old Mar 31, 2001 | 09:11 PM
Bill_Beyer's Avatar
Bill_Beyer
Bronco II help
If the engine is that new it may not be broken in yet and some oil is bypassing the rings. Double check to make sure the PCV is working and keep an eye on the oil level. If it continues then you may have broken ring(s) which would require a compression check to diagnose.
Old Apr 1, 2001 | 11:38 PM
blacklightningf150's Avatar
blacklightningf150
Bronco II help
Just wanted to say replace the PCV valve, the prob should go away i had an 89' bronco 2 and as soon as i replaced the valve it went away, also my dads F150 had the same thing happen and we did the same replaced the valve problem solved....
2000 F150 Extended Cab 4x4 Sport, all black
Head light covers
Tail light covers
"FordmotorSports sticker in rear window
Stereo upgrade soon need some "thump"
Old Apr 3, 2001 | 03:42 PM
77_F150_4x4
Bronco II help
