Help with a 460 Please
Old Jul 24, 2007 | 07:22 PM
fordtk12's Avatar
fordtk12
Have a 97 f-350 with the 460 in it Stats and runs fine when driving it, but at an idle and more when you put the truck in reverse but don't push the gas peddle the engine flutters. Like it is not firing right. So I put in new plugs, wires, high flow air filter, flowmaster exhaust, 02 sensor. Still does it. When I took the old plugs out they had like a gumish residue on the threads of the plug. Any thoughts? this truck sits and idles more than it gets driven down the road. Could the CAT be half cloged? Do these trucks have an EGR valve? The truck also seems to run really Hot even after the flowmaster which should help to keep it cooler. Anyone have any ideas?
Also changed the oil and filter not like that would have been the problem anyway but just was time for it.
Old Jul 24, 2007 | 10:12 PM
darrin1999's Avatar
darrin1999
how many miles? if over 100k you could have a stretched timing chain. that would do what youre describing. the residue on the plugs is probably anti-sieze.
Old Jul 25, 2007 | 11:52 AM
fordtk12's Avatar
fordtk12
The truck only has 11,500 miles on it. It is the Brush Truck with the Fire Department. It doesn't see many miles just alot of sitting at idle.
I don't think what was on the plugs was anti-sieze only because it was a brownish yellow color. I could be wrong though
Old Jul 25, 2007 | 11:25 PM
buffalobob's Avatar
buffalobob
put some miles on it at highway speed & use up the pld gas.......
the poor thing is probably chomping at the bit to get unleashed you only put about 1000 gal of gas thru her in the last 11 years.....burn some fresh gas probably wont flutter then
Old Jul 26, 2007 | 09:04 AM
darrin1999's Avatar
darrin1999
its probably all carboned up from just idling and not getting driven... as said take it out on the interstate... as fast as you can go without getting pulled over... for a couple hours. then come back and pick up a bottle of seafoam... pull the vacuum brake booster line off (or other handy manifold vacuum line) and suck a little seafoam at a time through the line until the bottle is about half gone... then throw the rest of the bottle into the gas tank... that should clean your injectors and clean out the carbon from the engine and make it run like it should.
Old Jul 26, 2007 | 10:30 AM
fordtk12's Avatar
fordtk12
I have put some cleaner from napa in the tanks but I will put some right into the manifold and see what happens
Old Jul 26, 2007 | 11:01 AM
fordtk12's Avatar
fordtk12
Will it hurt anything to disconnect the EGR vavle?
Old Jul 26, 2007 | 06:30 PM
darrin1999's Avatar
darrin1999
computer doesnt like that... youll get sucky mileage and a check engine light
