I have a 429ci that I pulled out of a 1968 or 1969? LTD last summer and before I rebuild it I wanted to know what I'll have to work with. So if somebody can decipher this codes for me I would be very grateful.
Intake Manifold #:
C9AE-9425-A
Head #:
C8VE-E
Also will there be any more #'s that I will need in order to find out the specifics on this engine?
Hi, Check out the Official NHRA Tech/Specs page for Ford 1969 at http://www.nhra.com/tech_specs/engine/index.html --Both the head and intake are listed by FoMoCo as being used in 1969 on the 428/429, 320hp, sngl 2bbl Ford carb #C9AF-J/auto only-intake #'s near top of page, you'll find head nos. next to last at the bottom. This is a Good Site, Pass It On----justmerod----- p.s. if you rt. click on Ford 1969 then left click Open in New Window and Open File from current location; then you can minimize that window and browse other years. Good Luck!!
>--Both the
>the bottom.
Umm...the same head used on the 428 and 429...I don't think so!
>>--Both the
>>the bottom.
> so!
OK YOu caught me!! The Idea of my posting was to get get Josh to visit the site and read the #'s for himself. I mis-spoke though; Bill, in my haste in writing reply should have said the intake originated on the '69 429 and the heads orig. on the '69 428. --- I'd Stand Corrected, but I'm too tired, stressed out with Engine Woes of my Own and sorting through all the mis-information in Chat Rooms. Justme..duh!
I went to the site myself and read the same thing you did. If that's the caliber of information they give out then it's basically useless. 428 heads won't fit on a 429...never have, never will, they're 2 different engine families.
