TPS install help
Old Jul 24, 2007 | 06:00 PM
andym's Avatar
andym
Sounds like a fuel pressure problem. Does it happen on both tanks?
Old Jul 24, 2007 | 06:09 PM
subford's Avatar
subford
Originally Posted by RH F-350
hey subford, could you tell me the year and the size of the motor that the throttle body came off of? thanks.
The TB in the photos was of a TB from a 1988 E-150 5.0 AOD.
ncguy23's Avatar
ncguy23
Both tanks, replaced so far all filters (oil, air, crankcase, fuel), fuel pressure regulator, and now TPS, cleaned IAC.
Problem started about 2 1/2 weeks ago, pretty much as soon as the suspension got rebuilt.
Truck throws no codes KOEO, KOER
Old Jul 24, 2007 | 06:17 PM
subford's Avatar
subford
Check the fuel pressures with it off and at idle.
If the fuel is OK maybe the TFI (ICM) module or wiring.
Old Jul 24, 2007 | 06:27 PM
ncguy23's Avatar
ncguy23
I have nothing to test fuel pressure with, I guess thats one more tool I get to add to my. Is there anyway to test the TFI?
Old Jul 24, 2007 | 06:41 PM
subford's Avatar
subford
A lot of auto part stores will rent you a gauge for a deposit on it and then you get it back when you take it back,
They will test the TFI module for you also.
Old Jul 24, 2007 | 07:42 PM
quicklook2's Avatar
quicklook2
to make an tps non-adjustable into an adkustable:
https://www.ford-trucks.com/forums//...ad.php?t=79362
Old Jul 25, 2007 | 10:20 PM
ncguy23's Avatar
ncguy23
Checking fuel pressure in the morning, but after thinking about it I had a couple thoughts.
Its my understanding that when the TFI fails, it causes the truck to quit and there really isn't an in between, its either all or nothing.
A couple things I was mulling over that could be the cause: MAP sensor, engine mounts, exhaust leak/o2 sensor
Any ideas?
52' fordnut
Nov 19, 2012 09:50 AM
52' fordnut
Sep 23, 2012 10:06 PM
hustjona
Dec 26, 2005 06:45 PM
fordborn
Kansas Chapter
20
Apr 28, 2004 04:34 PM
Jon_S
Jul 1, 2002 06:22 PM
