Sponsored by: Real Truck
Upper console computer MPG
Old Jul 24, 2007 | 08:10 AM
tomsen5's Avatar
tomsen5
Question Upper console computer MPG
Good Morning. Is there a way to calibrate/reset the MPG part of the computer in the upper console. I routinely get 13.5 mpg and it will always reads 11.5-11.7. Thanks for your help. Steve
__________________________________________________ _
2002 F250 CrewCab Lariat V10 4x4
Old Jul 24, 2007 | 08:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
There is a reason they call it the Lie-O-Meter.
Old Jul 24, 2007 | 08:19 AM
tomsen5's Avatar
tomsen5
I see.....Maybe I'll just keep it on outside temp/compass.
Old Jul 24, 2007 | 10:18 AM
Beerstalker's Avatar
Beerstalker
Resetting it with every fill up should get you a little closer to the mileage for that fillup. But it's probably never going to be as accurate as doing the math yourself.
Old Jul 24, 2007 | 10:39 AM
tomsen5's Avatar
tomsen5
Hey Beerstalker...a fellow Illini, (I'm in the C-U area) How do you reset it??
Old Jul 24, 2007 | 10:46 AM
Beerstalker
Press the E/M and MODE controls simultaneously. The display will illuminate the “AVG” indicator. While the indicator is lit, release both controls to reset the average fuel economy.
Taken directly from your owners guide.
Red Monkey's Avatar
Red Monkey
To reset my 01 you, "Press both buttons at the same time". If this doesn't work check out your owners manual.
Hope this helps.
Old Jul 24, 2007 | 10:47 AM
redford's Avatar
redford
Here is a link to your owner's manual.
http://www.analogstereo.com/pdf/om/f...anual_2002.pdf
This is from your owner's manual:
Average fuel economy. The display will indicate the vehicle’s
average fuel economy in liters/100 km (or miles/gallon) since the
average fuel economy was last reset.
If you calculate your average fuel economy by dividing liters of fuel used by 100 kilometers traveled (miles traveled by gallons used), your figure may be different than displayed for the following reasons:
• your vehicle was not perfectly level during fill-up
• differences in the automatic shut-off points on the fuel pumps at
service stations
• variations in top-off procedure from one fill-up to another
• rounding of the displayed values to the nearest liter (gallon)
To reset the average fuel economy:
1. Press the MODE control repeatedly until average fuel economy is displayed (this is the only resettable display).
2. Press the E/M and MODE controls simultaneously. The display
fuel economy.
Old Jul 24, 2007 | 10:53 AM
tomsen5's Avatar
tomsen5
Thank You RedFord!!!!!!!
fifty-two_f1
May 5, 2011 02:46 AM
teppler
Feb 4, 2010 06:41 PM
k4uwc
Aug 5, 2008 09:59 AM
quality1construction
Apr 22, 2008 10:15 AM
wildcatv4
Jul 18, 2001 12:34 PM
