motorbogs down when hot outside
Old Jul 24, 2007 | 01:38 AM
P1ckup Man's Avatar
P1ckup Man
Whenever it gets to be around 85 degrees or higher outside. My truck will bog down on acceleration after it has set for a idle for just a matter of seconds. I have been told the gas is boiling in the carb so I added a 1 inch spacer under the carb but i still have the same problem. The engine is not overheating at all the temperature gauges read perfect. Lately it has been 90's to over 100 and its almost not worth takin out my truck.
Any suggestions on what it is, or anything I can do to fix this?
1979 f-150 4x4 Lariat
400 engine 600cfm Edelbrock Carb and C6 Tranny all recently rebuilt 5000 miles
Old Jul 24, 2007 | 09:44 AM
JBradley500's Avatar
JBradley500
I have a couple of questions....
Do you know which size jets are in the carb??
What material is the spacer made of??
Old Jul 24, 2007 | 10:09 AM
beartracks's Avatar
beartracks
Sounds like vapor lock. It's often more in the fuel pump than the carb. A weak pump, clogged filter or low float level can aggratvate things. Also things like a clogged sock pickup in the tank or a collapsing suction hose.
Old Jul 24, 2007 | 12:05 PM
Mil1ion's Avatar
Mil1ion
How much Rubber fuel line do you have on that truck ?
Steel line allows for cooler fuel to be delivered to carb.
Rubber hose attracts and holds heat.
Old Jul 24, 2007 | 04:46 PM
P1ckup Man's Avatar
P1ckup Man
The carb has the same jets it came with in the box i never checked what jets it has.
The spacer has a aluminum outside and a plastic insert that goes inside it with the 4 hole setup.
The steel fuel line comes up the front of the engine and probly 6inches to the fuel filter then another little piece to the carb i dont know exactly how much but its not real long. I can probly cut off a couple extra inches.
Im pretty sure it isnt the fuel pump. It did this with the old motor i had in it with the motorcraft 2bbl.
Old Jul 24, 2007 | 06:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Have the ignition module tested.
Old Jul 25, 2007 | 01:39 AM
trinogt's Avatar
trinogt
You just eliminated the chance of it being a fuel problem, or it's a great coincidence if two engines did the same thing under the same conditions... I would look at the electrical too... Try a junkyard module before spending a lot on new Ford unit (I had bad luck with jobber modules)
Old Jul 25, 2007 | 03:41 AM
460in503's Avatar
460in503
I replaced the I.C.M On my 77 for thirty bucks. A cheap fix for me.
Old Jul 25, 2007 | 01:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
The only good modules are the Motorcraft units. The aftermarket stuff is junk and not worth paying for. A good place to get a Motorcraft module is from a junkyard. Most of them are still good, just have them tested.
Old Jul 29, 2007 | 07:51 PM
P1ckup Man's Avatar
P1ckup Man
Last night i was driving home and it just died. I wiggled the slip on cap on the coil and it started right up. It wasnt making connection on the bottom wire. I will take a better look at it tomorrow.
