Head interchange question
Old Jul 23, 2007 | 11:01 PM
Chuck_Sloggett's Avatar
Chuck_Sloggett
I have a stock 69 302 in a fairlane 500. I am in need of a valve job and just wonder what cc the heads I have now are and what better heads I can interchange. 5.0 Mustang? GT-40 P? Are the mounting holes for acessories the same on the later heads? The current engine has an advertised 9.5:1 compression ratio.
Thanks,
Chuck
Old Jul 24, 2007 | 12:16 AM
Beanscoot's Avatar
Beanscoot
The chamber volume is 56.7cc - 59.7cc.
Old Jul 24, 2007 | 04:38 AM
HemiEater's Avatar
HemiEater
I'd keep those....just have hardened exhaust seats installed when you do the valve job.
Old Jul 24, 2007 | 05:07 PM
jhlf100's Avatar
jhlf100
GT-40 (p) accessory bolt size?
I'm in the same boat...trying to determine the accessory mounting bolt hole sizes on the end faces of the GT-40p heads. Any info would be appreciated...John
Old Jul 24, 2007 | 08:47 PM
jhlf100's Avatar
jhlf100
Ok, was able to decipher...accessory bolt holes are 5/16-18....the old heads have one hole that looks like 5/8" coarse for a power steering mounting bracket stud...has anyone drilled and tapped the GT40p for one of theses studs? are the water jackets the same as the older heads? J
Old Jul 29, 2007 | 10:39 AM
mrford49's Avatar
mrford49
Exclamation
Caution stay away from GT40P heads they need custom headers! The exhaust ports are higher and standard headers will hit the spark plugs. Hope this helps! Ron
Old Jul 30, 2007 | 06:10 AM
baddad457's Avatar
baddad457
The ports are not higher. The spark plugs are relocated vs other small block heads. I run a set of Canfield heads with raised by 1/2" ports and header fit is the same as any other head. I've interchanged two engine in the same vehicle and the headers, while a tad tight with one engine, is fine. I ran the exhaust with the Canfield heads, when I swapped in another motor with E7's, the dirvers side header was a tigh fit to the exhaust pipe, I simply omitted the flange gasket to fit. No leaks.
