The NOVI-2000 system is set at the factory to produce approximately 8 psi of boost on a stock 5.0L engine, but with the correct pulley can produce up to 27 psi and sustain 900+ horsepower on a modified racing engine.
Back to the original topic. I've actually found a camshaft that is very similar to my custom one. So this makes it's easier and cheaper to get the same performance.
The 302/351W shared the same camshaft. Flat tappet and Roller cams. This cam will only work in 85-2001 302 and 94-97 351W engines.
Here's the actual name:
Ford 5.0 Blower 270HR Cam
DESCRIPTION: HYDRAULIC ROLLER: Supercharged combinations with little or no additional modifications.
Have you seen my newest thread yet. I posted a link to another thread that has U tube movies. A sbf blows away a sbc, but reaches it dimize also but over 3 minutes later.
