Does size matter??
I just found out that OilGuard has knocked up their prices substantially on their replacement filter elements. I have the EPS-20 system myself, and began to search for alternative filter element resources.
What I discovered is that OilGuard is actually supposed to be the OEM for the Racor Filter elements on Racor's bypass filtration systems. Racor's systems look virtually identical to the OilGuard systems.
So what??
The OG EPS-20 system is, like I said, virtually identical to the Racor LFS801 unit, while the EPS-60 system is apparently comparable to the Racor LFS802 unit. On the Racor site, there is a lot of data and information about their filtration systems as compared to the meager information that you find on OG's site. The point is this, that the Racor LFS801 series filtration system is reportedly rated for 150-250 Hp engines, while the next size up (EPS-60, or, LFS802) is rated for up to 400 Hp engines.
So here's my question. If I take my engine and modify it up to say the 275-350 Hp range, which is probably where I will end up, am I going to need to change out the bypass filter housing and go to the larger filter element?
To the best of my knowledge, the things I am going to be doing to get up into those higher power ranges are not going to change anything in regards to how much oil flows through the engine block or oil bypass system, which makes me wonder why a larger element might be required as suggested by the Racor site. Or is the Racor recommendation possibly based on the assumption that the 250-400 Hp engine will already be built with larger oil flow processes, and their corresponding "ratings" really don't apply to a smaller engine that is modified to higher power capabilities?
I can't see me ever modding up to even 400 Hp, even though I know for sure that it would be a whole lot of fun to do so... the practical issues of family life just won't allow for it, and I know that I'll be happier overall by keeping "family first". You "youngun's" can go ahead and have the fun while you can.
