6.0 PSD barely moves when engine cold
Old Jul 23, 2007 | 05:39 PM
Ronin-M5's Avatar
Ronin-M5
Is it typical for the 6.0 PSD to take sometime to warm up and barely move when starting up in the morning? The beast can't get out of it's own way when cold. It takes a good 10 to 15 minutes before it drives normally. I have co-workers with Chevy Duramax's who can drive right away after starting in the morning.
The manual states not to let the engine idle for an extended period of time to warm it up, but when I do let it sit for a good 10 minutes, the car is much better to drive.
Old Jul 23, 2007 | 06:12 PM
RoyC's Avatar
RoyC
No, something is broken. I would take it to the dealer and have it checked out.
RoyC
Old Jul 23, 2007 | 07:37 PM
bigblock_drock's Avatar
bigblock_drock
ya it shouldnt be THAT bad, but when it is cold it is quiet sluggish
Old Jul 23, 2007 | 09:44 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If it's that cold and won't go anywhere, something is definately wrong. Have your dealer check it out. If they give you the "that's normal" line of bull, go somewhere else and get a second opinion. I know first hand about dealers that don't really care if you have a problem.
Old Jul 23, 2007 | 10:39 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
take it to the dealership that is a problem
Old Jul 23, 2007 | 10:47 PM
Ronin-M5's Avatar
Ronin-M5
Galpin Ford said it was normal
Last time the Excursion was in service, Galpin Ford said that it is normal. I had all of the fluids changed and the fuel filter at that time. I need to take the car back for service soon and have second thoughts about using Galpin Ford again. Any other recommendations and service writers to deal with?
Old Jul 24, 2007 | 08:20 AM
Toreador_Diesel
Just go to fordvehicles.com and type in your zip code. It'll show you info about every dealer in your area.
Old Jul 24, 2007 | 02:59 PM
Aatcntrl1's Avatar
Aatcntrl1
Mine had the same problem. I don't know how they can be related but the dealer found the vanes in the turbo stuck. They told me how it effects cold start up but I don't remember exactly what it was. THey replaced the Turbo and now it's not a problem. Still not a ball of fire when cold but not nearly as bad.
Old Oct 24, 2007 | 06:26 PM
GnFnRs's Avatar
GnFnRs
Any new info on this? i just bought a 6.0 x with 77,000 milesand it does this too. and it's not even cold here..only in the 70's when i noticed it.
Old Oct 25, 2007 | 11:35 AM
Ronin-M5's Avatar
Ronin-M5
After using another service writer at Galpin Ford, Leonard, and leaving the car for a few days, they were able to determine that a few injectors were not up to spec. Once the injectors were replaced, the car feels much better when first starting in the morning. There is still a slight lag in acceleration when you get going, warm or cold, but I think that is typical.
Old Oct 25, 2007 | 10:20 PM
V10raisinCane's Avatar
V10raisinCane
I had the same problem with my 7.3 PSD in my '01 F-250. I would have to start my truck, go get ready for work, and then, 20 minutes later, leave and it would run good. I changed the fuel filter and it solved that problem. Might want to look into that if it hasnt been changed in a while.
Old Oct 25, 2007 | 10:41 PM
GnFnRs's Avatar
GnFnRs
ok..sincei have 2 i guess i better do them both lol.
thanks for the info.
BarterOnlycom
Apr 26, 2013 08:33 PM
Shade
20
Jan 6, 2010 07:30 PM
wedge88
Apr 15, 2009 09:58 AM
PA_Ford_Man
Jul 26, 2006 03:30 AM
Wapiti Hunter
Nov 22, 2005 07:28 PM
