Starter problem??
Old May 13, 2001 | 11:50 PM
redtruck's Avatar
redtruck
Starter problem??
Please help me figure whats wrong. Sometimes when I go to start my truck the starter doesn't do anything, or just clicks, like it's not making a good connection until I pull up or push down on the gear selector(still in park). When I push down or pull up on the selector, it starts. Sometimes it sounds like I have a bad electric connection. The battery is new. Starter seems good most of the time. Could the problem be in my key switch? What will happen if I just leave this alone and keep driving? Will I burn up something? Thanks for all responses. Ray
Old May 14, 2001 | 01:21 AM
desperado_18_2000's Avatar
desperado_18_2000
Starter problem??
just sounds like a neutral safe switch to me.
1982 F-150 AOD 302
1976 f-100 Needs motor and tranny, lots more mods to come
Old May 15, 2001 | 09:36 AM
dre's Avatar
dre
Starter problem??
Ditto.
Some are on the side of the Transmission, and some are on the Steering shaft. Loosen the small bolts, use a drill bit 3/32" and push in the hole until both pieces of switch are aligned.
retighten bolts.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old May 15, 2001 | 10:45 PM
redtruck's Avatar
redtruck
Starter problem??
Thanks for the replys. What does the neutral switch look like? How do I know if its on the column or the transmission. Truck is a 1986 F150 with 302. Thanks again, Ray
Old May 16, 2001 | 07:52 AM
dre's Avatar
dre
Starter problem??
On the 86' its on the transmission.
I am not too sure if you can adjust that one or not.
It has a four prong wire that pushes into the switch.
Try adjusting your selector linkage or cable. At the trans. end.
Dre'
Old May 18, 2001 | 09:35 AM
redtruck's Avatar
redtruck
Starter problem??
Thanks guys for the help, I found the switch on the transmission and replaced it. It is working fine now. Thanks again, Ray
Old May 18, 2001 | 11:31 PM
Ben_E's Avatar
Ben_E
Starter problem??
