Sponsored by: Real Truck
2001 F250 trans problems.
Old Jul 23, 2007 | 12:25 AM
Jeeper for life!'s Avatar
Jeeper for life!
To day the overdrive light on the shifter stick started flashing. the truck drives fine and shifts through all gears, But it does shift hard. when it stifts it jerks the truck witch it has never done before. A week ago I added a bottle of conditner in it and It showed over full tonight. I will drain some out before work and see if that helps. any idea what is going on? It has a V10 4R100 combo 155,000 miles.
Thanks
Marcus
Old Jul 23, 2007 | 06:58 AM
redford's Avatar
redford
FTE Leadership Emeritus
You need to get someone to read the transmission error codes to see what is going on.
Old Jul 23, 2007 | 09:40 AM
aldridgec's Avatar
aldridgec
I've seen the temperature sensor in the solenoid pack go bad. It will go open, making the computer think it is over heating, causing the light to flash. It raises the line pressure way high causing the shifts to bang.
But get it scanned.
