First Attempt
Old Jun 11, 2001 | 12:28 PM
Kidd's Avatar
Kidd
First Attempt
Hello Ken,
I am going to build or try to build my 1994 Ford F-150 XLT,5L w/3.08 gear ratio, so it will rock on the streets : Headers,Dual Exhaust,K&N Air filter sys.,which Chip should I use to get the Max. H.P. and what is your thoughts on a Cam and could you tell me if this is a Roller Motor? Also where to start ??
Old Jun 11, 2001 | 05:37 PM
StrangeRanger's Avatar
StrangeRanger
First Attempt
Forget the chip, spend your money on gears. Change the 3.08 open diff for a 3.73 or 4.10 limited slip. Right now your engine doesn't even get into its power range in second gear on the street.
Old Jun 14, 2001 | 03:11 AM
Kidd's Avatar
Kidd
First Attempt
Thks Ken for info will look into re-gearing first then and will be back for more info:-)
Old Jun 14, 2001 | 01:29 PM
FTE Ken's Avatar
FTE Ken
First Attempt
Gearing isn't going to give more horsepower. It will give you more on the bottom end but it will lower the top speed of the truck and increase fuel consumption. You need to tell us what you're willing to give up to get more umppphhhh..... you can't get something for nothing. There's always trade-offs.
Ken Payne
Ford Truck Enthusiasts Admin
Old Jun 14, 2001 | 05:05 PM
StrangeRanger
First Attempt
For sure bigger gearing will reduce highway fuel economy, but it should have little or no effect on around town mileage. I read "make it rock on the street" as improved performance at the stoplight grand prix and a 3.08 open is not the gearset for that job.
Reduce top speed?? Right now his truck has a theoretical top speed in drive of about 150 MPH, changing to 3.73s would reduce that to around 125 and 4.10s to about 115. Given that trucks are aerodynamically challenged, I doubt that there is any real difference in top end.
Old Jun 14, 2001 | 05:12 PM
FTE Ken's Avatar
FTE Ken
First Attempt
What I said was not a rebuttal. It seems you're taking it that way. :-)
Ken Payne
Old Jun 15, 2001 | 04:28 PM
Kidd's Avatar
Kidd
First Attempt
Could you please tell me if the 5L in that year was a Roller Cam/Lifter setup -------- 1994 F-150 XLT 5L
Thanks, Kirk
Old Jun 16, 2001 | 12:23 AM
Kidd's Avatar
Kidd
First Attempt
