Neutral Safety Switch ???
Old Jul 22, 2007 | 07:08 PM
vesuvius5402's Avatar
vesuvius5402
What are the symptoms of a bad Neutral Safety Switch? I turn the key and get nothing at all. Battery, cables, relay, solenoid, starter are all known to be good. Could it be the NSS?? Or maybe one of the many fusable links in the ignition system?
Any thoughts or opinions will be most appreciated.
Thanks . . .
1981 F-150 4x4
Old Jul 22, 2007 | 08:27 PM
Franklin2's Avatar
Franklin2
If you want to bypass it temporarily, find the switch on the passenger side of the tranny, or on the clutch pedal, and take the plug loose. There should be two red/blue wires in the plug going into the harness. If you jump these two wires together, then that will complete the circuit all the time and bypass the switch.
Old Jul 22, 2007 | 11:55 PM
sasquatch999's Avatar
sasquatch999
I am personnally going through this right now -- feel free to check out my threads. There is a plug that goes to the neutral safety switch. When you unplug it there are two little connectors that can be jumped. When I thought my starting problem was with the NSS I kept a small nail nearby to jump the connection if I had trouble.
My trouble turned out to be elsewhere...I'm thinking (for now) the ignition switch. In your case, I wouldn't rule out the starter solenoid either.
Franklin as well as others have been incredibly helpful.
Good luck vesu....
Old Jul 23, 2007 | 09:31 AM
Sycostang67's Avatar
Sycostang67
If it was the NSS your engine would crank, but not fire. If you get absolutely nothing when you turn the key, something else is wrong.
Old Jul 23, 2007 | 12:16 PM
sasquatch999
It was my impression that the neutral safety switch worked inline with the ignition switch, and if the nuetral safety was not working, you would get nothing when the key is turned. At least that's what happened when I pulled the plug on mine.
Old Jul 23, 2007 | 12:33 PM
Franklin2's Avatar
Franklin2
All the neutral safety switch does is interrupt the current from the ignition switch to the solenoid that sends current to the starter. You will find the same red/blue wire on the starter solenoid.
So if you have a NSS problem, you will get the radio, blower and all that stuff in the run position, but nothing will happen when you turn the key to start. There are several other things that will make it not crank, but if it's intermittent, bypassing something is sometimes the best way to figure out the problem.
Old Jul 24, 2007 | 12:32 AM
johnsnewtruck's Avatar
johnsnewtruck
jump the starter solenoid
that way you eliminate that. check wire tightness too.
you can pull your starter and test it externally with 12 volts easy enough as well.
my 1 1/2 cents
as a rookie
Old Jul 24, 2007 | 10:07 AM
Sycostang67
D'oh, you guys are right. I had a brain fart. I had the right info in my head, I just put it together wrong. It's time for bed now.
Old Jul 24, 2007 | 07:51 PM
vesuvius5402
Thanks so much to all that replied for the words of advice and experience. This forum and those involved are great. Thanks again.
