Applying clear over paint
Old Jul 22, 2007 | 12:43 PM
bhardy501's Avatar
bhardy501
I was watching on TV and they were painting the door jambs and other areas of the trunk and under hood areas. After he applied 4 coats of paint with about 15 minutes tack time between coats he applied the clear. He didnt advised how long he waited to apply the clear or if there was anything he had to do before applying it. Do you just stick to the 15 minutes tack time and spray on just as another coat or do you have to let the paint dry first and then clear it? Is there anything special you have to do before you clear it?
Old Jul 22, 2007 | 05:16 PM
jwtimme's Avatar
jwtimme
need to refer to the tecnical data sheet for the paint system you are using, but most of the time you wait 30min for the paint to flash off then spray the clear.
