Formaldehyde Odor
Old Jul 21, 2007 | 11:35 AM
nut1605's Avatar
nut1605
Formaldehyde Odor
Last night when we came home from shopping, we noticed our house had a pretty strong formaldehyde odor, concentrated in our bedroom (figures). After trying to find the source of the smell, and turning on and off various things, we found that when we turned the A/C off, the smell went away, the A/C comes back on, and the smell is back. This makes sense as to why the smell is strongest in our bedroom because the A/C is right over it, and the bedroom is the first vent out of the A/C. Now, what in the A/C could be causing this? A friend of mine thinks that the water could be growing some type of fungus, so to drain the water and add some bleach and it should go away. It doesn't smell like a motor burning up or anything, so I am kinda lost. Any ideas? Thanks guys!
Old Jul 21, 2007 | 11:40 AM
jake00's Avatar
jake00
thats very strange
Old Jul 21, 2007 | 12:35 PM
Aztrainer's Avatar
Aztrainer
When is the last time you changed the filter and where did you get it from? I bought my son a backpack from Target and it smelled like pesticide. I Fabreezed it to the point it was wet and put it into the dryer with five bounce sheets. It still smelled as if there was some spray in the bag. If the filters were shipped with a pesticide and it got onto the filter it could have impregnated it and that is what you smell.
This is just a guess.
Plus I thought AC's were a closed system.
Old Jul 21, 2007 | 02:27 PM
King Triton's Avatar
King Triton
Originally Posted by nut1605
Last night when we came home from shopping, we noticed our house had a pretty strong formaldehyde odor, concentrated in our bedroom (figures). Any ideas? Thanks guys!
Man,if that aint Deja Vu!My ex-wife used to have a perfume called, "aud de formaldehyde".That crap stunk so bad the dog buried it!
But your friend might be on to something there,I think I would check the drain,to make sure it was not clogged,and I would check the filter,better yet,change the filter.Even if the smell is not coming from the filter,the smell will permeate into it.And I would also check around my air ducts to make sure there is nothing creating that smell.
Old Jul 21, 2007 | 03:16 PM
ranger1999 Bob's Avatar
ranger1999 Bob
id get an ac guy in there just to be sure.. if it smells that bad it cant be good to breath it and you dont wanna mess with that kind of thing
Old Jul 21, 2007 | 05:07 PM
nut1605's Avatar
nut1605
Originally Posted by Aztrainer
When is the last time you changed the filter and where did you get it from? Plus I thought AC's were a closed system.
I think I might have not been clear and we are talking about two different things here. I have evaporative cooling, not refrigerated air, therefore, I do not have a filter (at least I don't think I do), I just have the pads the water drips through.
At any rate, I think I got it fixed. I decided to go ahead and replace the pads as we have really nasty, hard water here, so it wouldn't hurt. As it turns out, the pads had all kinds of mold and mildew in them, and there was so much lime scale in them that they broke when they hit the ground. While I was on the roof, I went ahead and replaced the pump, belt, and oiled the squirrel cage as well as drain and deodorize the water. Turned it all back on and all I have now is just the "new pad" smell. SO, I think it is fixed, and the culprit were the nasty old (Only 1 year old though) pads. Thanks all for the advice!
Man, that is hilarious. After having a "Murphy's Law" type day on my roof, that is just what I needed!
Old Jul 21, 2007 | 06:05 PM
Aztrainer's Avatar
Aztrainer
Yes, you and I were on a different page.
We had swamps in the house I grew up in. Change the water and also look at the pads on the sides of the panels. They need to be replaced from time to time. We had to do it every year because our water was so hard. I could cut (and often did) my hands trying to take out the old pads.
Old Jul 21, 2007 | 06:08 PM
nut1605's Avatar
nut1605
That sounds just like our water. It is so hard it is rediculous. I go through 1 filter everytime I wash my truck with that "Mr. Clean" thing. At my parents house in Albuquerque, we washed 2 Super Duties and a Mustang and the filter still looks new. I hate our water!
Old Jul 22, 2007 | 11:17 AM
jimdandy's Avatar
jimdandy
Have you paneled any of the rooms in the house. Paneling is treated with formaldehyde. I built an office several years, and couldn't use the damn thing because of the crap. It was so bad, it burned your eyes. jd
Old Jul 22, 2007 | 12:46 PM
Aztrainer's Avatar
Aztrainer
I think our water has the consistency of rocks....
One thing that will help you out and what we started to do was to use the roil pad (the one that looks like honeycomb). Once the season was over we would take them out and put a cover over the units. That way the water/lime/calcium/concrete that makes it so difficult to remove will not have time to set up. We also put a zinc strip in the pans and that seemed to help with the calcium.
ford2go
Jan 17, 2009 11:39 PM
bcjim
Sep 27, 2008 06:22 AM
krewat
22
Oct 22, 2005 09:06 PM
websthes
Dec 14, 2004 05:07 PM
alanscott
Jul 5, 2003 04:05 AM
