won't start need help
Old Jul 21, 2007 | 07:59 AM
90_F-150_302_2wd's Avatar
90_F-150_302_2wd
Cool won't start need help
my truck won't start but has gas, timing, spark, and compression. don't know how to test air intake. It is cranking slow and smells like the gas isn't burning. any ideas?
will
Old Jul 21, 2007 | 08:14 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
If it's cranking real slow you might need a battery or you could have a bad starter. Check all your grounds in the battery circuit and make sure the terminals are clean. Try starting with a jump if you can.......
Check the starter connections at the solenoid and the starter. Make sure they are all clean and have good grounds.
Others will chime in with more ideas soon.
Good Luck
Bob
Old Jul 21, 2007 | 08:23 AM
90_F-150_302_2wd
thanks the starter just burnt up yesterday getting a new one in a couple days all my grounds are good i just changed/cleaned them
will
