Fuel pump cost?
Old Jul 21, 2007 | 12:41 AM
JL63's Avatar
JL63
Fuel pump cost?
I was wondering if anyone knew what it most likely cost to get the front fuel pump replaced by a shop or dealer (in other words I'm not doing it) in my truck?
Thanks!
Old Jul 21, 2007 | 12:49 AM
Dean88's Avatar
Dean88
Are you talking about the intake pump, or the pump on the frame rail?
cletus_the_red's Avatar
cletus_the_red
i think the fuel pump will range between 60 - 160, depends on if it comes with the sending unit. i dont know what labor would cost, as i do it myself. hope this helps a little. (mine was 60 for the pump, and 100 for the sending unit.)
Old Jul 21, 2007 | 05:38 AM
44dwarf's Avatar
44dwarf
Well it depends on the year of the truck.
My 96 has hi presure pumps in the tank vs my 89 with a low psi pump in the tank and a high psi pump on the frame rail.
My 96's front pump die and i got the cheapest pump i could find (darn truck cost me alot with in weeks of buying it) at $90 and 6 hours to put it in. Now i've got problems with it and it has to come back out...............
The pumps ranged from $90 up to $350 at the parts stores.
GET new TANK STRAPS they may look fine but there thin trust me.
44Dwarf
Old Jul 21, 2007 | 08:42 AM
lostin90s's Avatar
lostin90s
I swap these tanks all time 2 hrs to get out and 1 hr to get in on most. You can get part at dealer but Don't have work done there. As the will want to replace everything while in there. Sender ETC. I'd say 6 hrs to cover your but and the pump cost ?? I have a stash of used ones I use. In the rust belt It helps to take down tank to spray oil any way.
LOST
