Sponsored by: Real Truck
Drop Kit for a 4x4?
Old Jul 20, 2007 | 06:38 PM
TheycallmeNASty's Avatar
TheycallmeNASty
Drop Kit for a 4x4?
Has anyone seen drop or lowering kits for a 2000 F250 4x4?
Old Jul 20, 2007 | 07:34 PM
Mike11C's Avatar
Mike11C
You're kidding, right?
Old Jul 20, 2007 | 08:14 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
How far down do you wanna go? Inch-wise, anyway
Old Jul 20, 2007 | 08:17 PM
redford's Avatar
redford
Well, I suppose you could start with smaller blocks on the rear axle.......
Old Jul 21, 2007 | 12:19 AM
aldridgec's Avatar
aldridgec
No, I've seen the for the Chevy's but not the ford 4x. It will be tough in the front because of frame clearance to go very low at all.
Old Jul 21, 2007 | 09:35 AM
NS F250's Avatar
NS F250
This is just plain wrong. Sell it and buy a 2 wheel drive.
Old Jul 21, 2007 | 10:12 AM
krewat's Avatar
krewat
OK, so far, it's 2 out of 5 answers that are negative.
PLEASE - don't gang up on the guy - if you don't like it, don't post
Old Jul 21, 2007 | 11:56 AM
RagingBull2k2's Avatar
RagingBull2k2
get leaf springs from an older truck? I think the old F-350's (before they were SD's) had leaf springs with a negative arch on them... I have NO idea why you would want to lower a Super Duty, but its a possibility those older leaf springs may fit... but like someone else said, you will very likely be riding on the bumpstops with a 3" drop in front... the rear would be fairly simple, as you could remove the rear block, droping it 2", if you a 250... like others have said, you might be better off getting a 2wd truck, but your call ...
Joey
Old Jul 21, 2007 | 11:58 AM
mstiles19's Avatar
mstiles19
Why are you dropping it??
Old Jul 21, 2007 | 01:54 PM
aldridgec's Avatar
aldridgec
Arrgghhh. This pisses me off. Why is a truck a particular color, why is it gas or diesel, or supercab or regular cab.
For the most part because that is what the guy who owns it wants. There are a lot of reasons for having a four wheel drive with a lowered look.
Not all trucks go off road and need tons of ground clearance. Sometimes the road can be bad enough to need 4x4. How about those slimey boat ramps? Need tons of ground clearance there right?
Personally I think slammed dually's look pretty good. In fact I'm doing a customers truck next week. 5 inch drop in the back. It's dually and 4x4. But regardless of what I think looks good is the guy who bought the truck and is paying me to do the work.
Old Jul 21, 2007 | 01:57 PM
aldridgec's Avatar
aldridgec
The reason the 2wd's can be lower is b/c the Twin I beam suspension is offset at the end. Can't do that with the monobeam 4x4 (or TTB 4x4 either)
Old Jul 21, 2007 | 11:43 PM
TheycallmeNASty
actually I drive an Excursion don't like the gaps in the wheel wells don't go off roading seen some lowered Xs and think they look pretty damn cool. I like the look of lifted trucks on 35s also but I live in downtown atlanta ga and I already have to struggle not to roll over hondas and curbs. and if I lifted it I wouldn't be able to park her anywhere. as far as how low goes I'd like to go a few inches lower than a stock 2x4 but would settle for the stock 2x4 ride height. thanks guys
Old Jul 22, 2007 | 01:35 AM
krewat's Avatar
krewat
First, if there's any blocks in the rear, remove those.
For the front, a weaker spring or a custom setup from a local leaf-spring shop will do the trick.
Old Jul 22, 2007 | 04:22 AM
phil6608's Avatar
phil6608
I found a 3/4 drop kit for my F-150 4X4 but don't know if they would have one for the F-250
Go it from Ground Force!
Old Jul 22, 2007 | 04:29 AM
aldridgec's Avatar
aldridgec
That is why, you have independent from suspension. I really think the hangup here is that there is only a few inches of clearance between the axle and frame to begin with up front, so without major surgury, it can't be done.
