Trouble starting...
Old Jul 20, 2007 | 06:10 PM
jndeere01's Avatar
jndeere01
Trouble starting...
OK Guys.....time to impress me with your knowledge.....I have a 72 ford F100 Ranger xlt v8 390. I am having trouble starting the beast. I have taken the starter off and had it check, it's good. I replaced the starter solenoid, and i ahve unhooked the battery and had it check, it's good. When i turn the ignition key it sounds like a buzzing sound or kind of like the sound when you touch the side of the game OPERATION when you are removing a game piece. What am i missing here....
Thanks
Stumped.
Old Jul 20, 2007 | 09:33 PM
59pan's Avatar
59pan
I just went through this and what mine was: the insulation on one of the small wires to the solenoid was ed, and the wire was grounding out on the inner fender. Little tape, and I haven't had the problem since. Same noise you describe.
Might isolate the wires and see if it will start.
Old Jul 21, 2007 | 12:54 PM
390fe's Avatar
390fe
It sounds as if there's a bad electrical connection in your starter circut. I would start at the battery, and pull apart every cable, inspect the connections, clean them, and reassemble them. Sooner or later, you'll find your problem.
Old Jul 21, 2007 | 02:45 PM
Danger_Dave's Avatar
Danger_Dave
could it be any of those rediculously stupid thin wires going from the key through the harness that plugs into the coil or distributor?
kandim123
Mar 31, 2013 06:06 PM
bigfix
Jan 1, 2012 05:39 PM
oneminizut
Washington Chapter
37
Apr 4, 2007 11:37 PM
budhead1
Jan 27, 2006 04:10 PM
