Sprung a leak.
I am doing a little bit of driving with it and hope to improve her little by little.
During the flush, I found out I have a few holes up high (upper 6 inches or so of the fins, front and back, and at least one on the seam near the top of the radiator).
Can someone explain to me the lingo regarding radiators?
I was reading old posts to see what I needed to do (actually to see if anyone talked about throwing 'stop leak' or something like that in the radiator) and kept reading about the 'core', 'lower ?', 'upper ?', re-coring' and '2/3/4 ? cores'.
Sorry about the question marks, it was late and about a week ago when I went through the old posts.
My neighbor said 'pull it and he can get it patched', but again, I am not sure if that is a bubble gum (temporary) solution or permanent. I am also curious, how you patch a radiator.
Another tidbit of information (relevant, I don't know). The left 4 - 6 inches of the radiator were cool to the touch after doing the flush, filling with water, and running 20 minutes. Does that indicate I do not have flow through that part of the radiator or something else? Serious or kinda serious, or just 80% efficient instead of 100% efficient.
The other thing that caught my attention in the posts talked about painting (or not painting) the radiator because it would insulate it and reduce the effectiveness of disapating heat, or something like that.
And I guess one other thing.
Does anyone know if the pet friendly coolant/antifreeze is better/worse then the regular stuff. The cost was the same and I thought if I was going to be leaking a bit, it made sense to keep from killing a few of the local critters.
Hope everyone has a good weekend.
The finned area between the tanks is the "core". This carries the coolant between the two tanks. This is that the air passes through and cools the small tubes carrying the coolant.
If you have a top and bottom tank, you are a down flow radiator. If your tanks are on the sides, you are a cross flow radiator.
If you look into the radiator cap neck and look down into the bottom of the top tank towards the core (without any liquid in there) you will see a series of oval or round holes going towards the other tank. If you count the number of rows that are open and being used, that is how many "core" or "row" tank you have. Most tanks will hold 4 cores but only 2 or 3 are used. The remainder of these holes are plugged off (soldered).
More is not necessarily better. You can actually stop the air flow through the cores with a 4 row where a 2 row would do the job. It's all a balancing act. If you plan a lot of highway driving at high speeds or going to the truck races at Daytona, you could use a 4 core or thicker because the air will be forced through the fins at speed. If you do a lot of around town driving, I would look more towards a 2 core or 3 core with wider fin spacing.
You can get cores in many configurations. Fin count/spacing, length and width, material are all considerations.
Painting a radiator is OK as long as you don't glob on the paint. A light coat for color is OK but stay away from the heavy coats. The tanks can stand a little more paint than the core can. Just mist the core to tinge it black. An old radiator shop may have special paint for this. Many just give it a squirt out of a common spray can.
If one side is cold to the touch, I would be willing to bet somebody has already used stop leak and a portion of your core is plugged.
I would suggest taking your radiator out, getting it to a good old fashioned radiator shop and having it boiled out, repaired/recored as they suggest and being happy all summer vs fighting heating problems.
Another thing to watch is that once the radiator is in top shape and you are getting full flow, your heater core may be the next thing to go. Always seems to work that way for me!
SPark
Thanks for everyones feedback.
I couldn't tell you how if it is a 2 core (I think it is) or not. I think I read this, but could not tell an obvious see of it by looking into the radiator.
Looks like the wise thing for me to do is pull the radiator and have it done right the first time. Also, a good opportunity to replace the hoses, I'm thinking.
Thanks for your help, and hope the heater core hangs in there Thinking about bypassing it actually. Well, I'll probably leave it alone until it causes me a problem. This in not a show truck, so some spillage won't hurt me at this point.
