99 no start only when cold
Old Jul 20, 2007 | 11:50 AM
viperrtblck's Avatar
viperrtblck
i posted before and i replaced my cam sensor with the new grey one. anyways i found out now that the probelm only persists when the engine is cold and not been run(mornings). well i was at country thunder last night and seh WAS NOT starting...ran the batteries down and it was 3 am and my buddy came up and messed with the ipr connector and then it fired...STILL my tach does not register while cranking until right before it fires? so i would think cam sensor still with no tach registration. ANYWAYS...i had a 97 truck before that i replaced the ipr and kept the old one...what i want to know if if cleaning my connector for the ipr DOES NOT WORK...can i put the solenoid (part of ipr with electrical connector) from my 97 truck...onto my 99..yes it is better to replace the whole ipr, but its easier for me at this point in time to just try putting a different solenoid on it. will this work ?...i took the one off my 99 (solenoid only) and compared it, they look identical...will this work if i try it or are the ipr's different?
found part number off the one from my old 97...and the 99...
97 is....1825250C91
99 is....1825249C91
Old Jul 20, 2007 | 11:56 AM
just another truck's Avatar
just another truck
I am sorry, what is IPR, what is cold? I would have gone after the glow plug relay and checked it first, but again, what is cold, where are you at?
Old Jul 20, 2007 | 11:59 AM
just another truck
Sorry, just went to your profile, found out IL, but what is cold? IF you dropped down to 48 ( like we did last night i hear) i would still look at the Glow plug relay. Also, just learned something other day, are you parked on incline? if so, go to level ground, try it.
Old Jul 20, 2007 | 12:08 PM
viperrtblck
temps are about 60 bein the coldest at night right now. and cold meaning just not run in a long period of time is what i meant.
Old Jul 20, 2007 | 12:36 PM
mxfam4x4's Avatar
mxfam4x4
does the engine smoke at all while your cranking it over? if so I'd bet on glow plug relay or bad glow plugs. just replaced all my glow plugs & what a difference.
Old Jul 20, 2007 | 12:57 PM
just another truck
Is it a complete no start, you are not able to start it at all right now? Or later in the day you can start it.
Old Jul 22, 2007 | 03:07 PM
viperrtblck
glow plugs and all are fine...no smoke at all when cranking OR once started..
and it barely starts when cold but once it's got temps to it..it starts fine.
i replaced the ipr solenoid from the one off my 97 and it made a difference...still could prolly use that actual ipr valve that goes into the hpop, but i just did the solenoid for now.
Old Jul 22, 2007 | 03:32 PM
just another truck
Very glad to hear it!! Nice job.
Old Jul 22, 2007 | 11:30 PM
viperrtblck
yah thats what i thought--but not so fast...i just started it up once again after sitting for 5 or 6 hours and at night when it's cooled off to about 70 degrees..and it cranked for a long time again...i'll the whole ipr valve and everything in it off my 97 and see if that does anything since messing with the solenoid seemed to help(or so i thought). anybody got any other suggestions?..what gets me still is that when it's cranking the tach isn't moving, but once it starts to fire the tach moves....way to odd?
by the way; anybody know where to find cheap ipr's for the 7.3?..if they even exist?
Old Jul 22, 2007 | 11:53 PM
viperrtblck
when the ipr is replaced...is all the oil from the resovior and pump going to drain out through the hole when i remove the ipr?...i believe it will.
Old Jul 23, 2007 | 07:48 AM
Kwikkordead's Avatar
Kwikkordead
Are you sure your glow plug relay is passing current? They click but the contacts inside get so fried that nothing goes through.
Old Jul 25, 2007 | 05:50 PM
viperrtblck
i checked relay- it's got operation when clicking. voltage is present..i also replaced the whole ipr assembly with the one from my 97....and the problem is persistent. possibly idm? lately the problem hasn't been occuring..i really need a solution.
Old Jul 27, 2007 | 11:09 AM
just another truck
I have no info to add, just following up, have you found the problem?
Old Jul 27, 2007 | 05:27 PM
Action4478's Avatar
Action4478
Have you checked the HPOP Resevoir at cold start up to make sure it is full...1/2 inch from the top....
Does it stay running when cold?...
Old Jul 27, 2007 | 08:41 PM
viperrtblck
hpop resovior is full of oil...when cold..and once started cold..it idles and runs just fine. i DID replace one battery that checked out weak when load tested...problem hasn't occured....yet
deleontow
Jun 16, 2015 12:15 PM
99ExpyProblems
Nov 14, 2014 08:37 PM
cope1972
Sep 22, 2014 06:51 AM
Ryan313
Dec 20, 2013 08:47 PM
cartmanea
Oct 31, 2013 02:35 PM
