Sponsored by: Auxito
Tire size again!
Old Aug 9, 2002 | 12:37 PM
JabberJaw's Avatar
JabberJaw
Tire size again!
I have a 97 F-150 that currently has 285x75x16 tires on it. The stock size was 235x70x16. I feel as if the power is greatly reduced, and that it shifts late when climbing hills. What kind of difference can I expect if I go purchase the stock size tires?
Old Aug 9, 2002 | 01:18 PM
MrBSS's Avatar
MrBSS
Tire size again!
You can expect a major difference, especially if you have a high (numerically low) final drive ratio.
To tell exactly, you need each tire's "Revolutions Per Mile". You can get that at the dealer or at tirerack.com. Multiply the ratio of the oversize RPM to the stock RPM times your final drive ratio to get the effective drive ratio.
For example, if the os RPM / stock RPM is .9, then a 3.55 axle will seem like a 3.195.
MrBSS
Old Aug 19, 2002 | 10:02 PM
rkjerue's Avatar
rkjerue
Tire size again!
[updated:LAST EDITED ON 19-Aug-02 AT 11:03 PM (EST)]A good compromise is either a 245/75-16, 255/70-16 or a 265/75-16. I put the 265/75-16's on my 97 F-150 4.6 2WD and noticed almost no power loss.
Old Aug 19, 2002 | 10:10 PM
rkjerue's Avatar
rkjerue
Tire size again!
jsanta
Mar 29, 2012 09:08 AM
caddylt1
Dec 9, 2007 11:21 PM
dyna
34
Nov 4, 2007 07:09 PM
Scoop531
Apr 9, 2007 02:13 PM
jettfuel
Apr 11, 2003 02:08 PM
