vibration at 110kph/65mph
Old Jul 19, 2007 | 03:51 PM
1bigmofo's Avatar
1bigmofo
2003 5.4l expy, would warped rotors cause vibes at highway speed?(brakes not applied). the steering wheel shakes pretty good when brakes are applied at that speed, so I'm thinking new rotors. just got new tires installed also, still vibes. Just bought it about 3 weeks ago.
Old Jul 19, 2007 | 03:55 PM
vindiesel6.9's Avatar
vindiesel6.9
could be rotors or wheel bearings, you can have the rotors turned for around $10 each if you remove them yourself and if they are bad the shop will tell you.
Old Jul 19, 2007 | 05:09 PM
Rentaltux's Avatar
Rentaltux
I had the same prob on my 03 5.4 expy. New tires, balance and wheel alignment... slightly better. New brake rotors... slightly better yet. Took it to a tire shop with a balancer that balances from the bolt holes as opposed to traditional cone type balancer and found out the balance was quite off....fixed finally. Best 20.00 I ever spent. I would get them rebalanced first then go for the rotors.
R
Old Jul 19, 2007 | 05:14 PM
High_Horse's Avatar
High_Horse
Have your bearings, tie rods, steering arm and idler arm checked also. Yes, rotors can cause a vibration at speed without braking applied if they are warped enough. I found my rear rotors badly warped last summer when we tried everything else for a vibration.
Old Jul 19, 2007 | 05:27 PM
1bigmofo's Avatar
1bigmofo
Thanks guys, I guess I could have thrown a weight too, off to get a rebalance first, thanks again.
Old Jul 19, 2007 | 06:13 PM
vindiesel6.9
Though I have not tried these I hear they work wonders.
http://www.innovativebalancing.com/gallery1.htm
Steve_250
Jul 7, 2013 09:50 AM
freerider
Sep 12, 2010 01:15 AM
leviticus
Dec 13, 2009 11:48 AM
rferoni
2004 - 2008 F150
15
Jul 4, 2005 10:45 PM
dpoelstra
Sep 29, 2002 10:18 PM
