Sponsored by: Auxito
temp adjust knob...
Old Jul 19, 2007 | 12:25 PM
beanydaddy's Avatar
beanydaddy
temp adjust ****...
Hey all,
My temp control **** has taken a crap. When you turn it, it just spins and does not adjust the actual temp from cold to hot. I am looking to find out what is involved in the replacement of this item. Cost and what it is called so I can ask for the right part when I go to the auto parts store.
Thanks in advance,
Jay.....
Old Jul 19, 2007 | 12:54 PM
ncranchero's Avatar
ncranchero
Have you pulled the **** off to see if the shaft turns and turns and turns and turns......?? I mean is the **** broken or the control? Either way it's a dealer item, or salvage yard.
KingRanchMan02's Avatar
KingRanchMan02
This is a common failure. Should be able to pick up a replacement **** at the dealer, but you may find one at AutoZone or places like that. Good luck!
Old Jul 19, 2007 | 08:06 PM
Markdale's Avatar
Markdale
I had the same problem in my 99 and when I took the **** off I could easily see where it was cracked so I stuck a small slot screwdriver into the shaft hole just enough to spread it a bit and then put a drop of Krazy Glue into each crack. After that I lightly clamped the cracks back together with needle-nosed vise-grips for about 5 minutes (overkill) and then put the **** back on and it works like new...YMMV.
J.R.
Old Jul 20, 2007 | 06:47 AM
ncranchero's Avatar
ncranchero
Ymmv ??????????????????
Old Jul 20, 2007 | 10:10 AM
projectSHO89's Avatar
projectSHO89
google it....
Old Jul 20, 2007 | 10:17 AM
projectSHO89
dup.... deleted
Old Jul 20, 2007 | 10:21 AM
ncranchero's Avatar
ncranchero
Originally Posted by projectSHO89
google it....
Oh thank you!
google it = 8 letters
your mileage may vary = 18 letters
Glad you didn't wear yourself out typing 10 extra letters for a real answer!
No wait, you posted twice, that would have been 2 extra letters.......
