M5OD rebuild info
Old Jul 19, 2007 | 02:33 AM
patricdoyle's Avatar
patricdoyle
M5OD rebuild info
Greetings. New here. I posted this over in the tranny section also.
I wonder if I can be directed to a pile of info about rebuilding a M5OD r2 (m5r2, etc). I have a 92, 2wd, stndard cab, long bed, 300 6I, F150. The tranny ground to a halt the other night on the freeway. definitely busted. i found another tranny out of a 92. It probably works just fine. While it is out though I think I should rebuild it. Unlike some other posters I read, money is an issue. Very quickly the rebuild here in Anchorage would be 2200 bucks. The price of another f150.
So, I'm confident I can rebuild it, with the help of some friends, but I want to find as much info as possible.
I heard Ford has a shop manual in pdf that can be downloaded. If not from Ford, does it exist elsewhere? I have Chiltons covering 87 to 96. Also Ludels F-Series owners Bible (not helpful concerning mazda tranny rebuild). I've found some stuff on Google but the most extensive one is for a Thunderbird and I believe it is a M5R1.
Where would you suggest I buy a rebuild kit? Drivetrain's site?
I have another 96 f150 so I can go slow, do the learning curve and get it right. I also have the busted tranny and the working one. Any info I can be steered to would be appreciated.
Is there a section, FAQ, Forum that I've missed on this group? Thanks!
Old Jul 22, 2007 | 09:58 PM
ameritaz3038's Avatar
ameritaz3038
go here and look at post #17
https://www.ford-trucks.com/forums/5...ir-manual.html
this no pdf but it will give some help
Old Jul 22, 2007 | 11:05 PM
radialarm's Avatar
radialarm
Try southwestgear.com. They have a manual either Ebook or hard cover plus if you buy their book you get 30% off parts and unlimited e-mails to ask questions. I need the bearing and syncro kit, a slider, and two gears And it's going to cost me a little over $200. Tell them you heard about them from Robert Harden.
BEAL73
23
Jul 12, 2021 09:48 PM
mototrig
69
Jul 4, 2014 10:53 AM
Randy Browning
New Member Introductions
Jun 10, 2014 03:21 PM
robprime
Feb 19, 2008 12:20 PM
