I had the opportunity to chassis dyno my truck at a local diesel service provider. It was my first time doing this so I was a little nervous, but it was definitely a lot of fun. They crew running the show actually did everything for you, so I was able to stand back and watch. My mods are listed in my gallery, I was hoping for 300rwhp, but didn't quite make it.
278.77rwhp @ ~2750rpm
559.07 lb-ft @ ~2450rpm
Maybe it's just me, but the torque numbers seem to be kinda high on the rpm range, I would have thought the max torque would have been a little lower, more around 2000, but maybe it's because it's a V8. I know I6 (tractors and such) peak between 1700-1900rpm.
It was definitely worth it though, proved to me that all the mods I have been doing are paying off and I'm getting my money's worth for what I've put into it.
I just wish I was there earlier to watch a '98 Dodge turn out 525rwhp, that would have been a nice smoke show.
Where's the dyno sheet? Those are good #s at the rear wheels. Imagine what it would look like stock. Just curious about your hp and torque curve. My dyno sheet is in my gallery if you would like to compare the curves.
Maybe it's just me, but the torque numbers seem to be kinda high on the rpm range, I would have thought the max torque would have been a little lower, more around 2000, but maybe it's because it's a V8....
You're quite correct, your torque peak is around 2000 rpm, and I'd say you're putting out about 650 ft-lb there, which equates to 247.5 HP at that same rpm. Dyno operators seem to be more concerned with getting the maximum HP reading, and they don't fully load the engine down lower at 2000 rpm to get an accurate HP # at that rpm which is the way you measure the torque there. To get an accurate maximum reading at 2000 rpm, you have to go WOT at a much lower rpm to let the turbo spool up, and get let a maximum boost develop at 2000 rpm.
BTW, your 278.77 HP=532.4 ft-lb of torque, and the 559 ft-lb of torque=260.8 HP. Did you happen to watch the boost and EGT gauges and get those #'s? In general, HP=T*RPM/5252.
Gene could figure that out. I have a 373 gear and 285s. Get busy Gene.
Can do, but I need the diameter of the 285's on the truck and aired up. For example, my stock 265's at 83 psi measure 31.6". The most accurate way is to measure the circumference, and divide by Pi=3.1416 to get the diameter. I'll use 3.73 as the diff ratio, and I'm assuming a direct 1:1 gear for the dyno run. I can run the spread sheet, and post a pic here, after I get the needed input on tire dia.
Well. As everyone who saw my truck must have noted, they are rapidly becoming slicks. Matter of fact they are not much taller than the stock 265 spare now. I know because I looked at that. I made many passes at the strip after that. If I was to swag, which I'm sure Gene doesn't like, I would go with stock circumference of a Firestone 265 AT tire. I'm going to use the rest of their tread life on this trip and replace them. Aren't those tires 33" tall? Well maybe supposed to be. Just measured them on the truck. 31 1/2". Really wore them down. Spare 265 matches up nice now. So, go with 31 1/2 Gene.
I went with 31.6" because I think we're trying to reconstruct your dyno run at Smokin? Wait until you see my new post and spreadsheets about how to get HP to the ground, then you'll see why your tires are so worn out!
The following 3 pics are the RPM vs MPH table for a 3.73 diff, 3rd gear (1:1), and 31.6 diameter tires. You can also calculate exact #'s using RPM=(39.6525)(MPH).
