heating coil springs
Old Jul 18, 2007 | 02:17 PM
joewaldner's Avatar
joewaldner
I got an 86 2wd and was wondering how hard it would be to lower it, I've heard of people heating the coil springs red so they compress a bit, is that a good idea? ... its just for the meantime, as soon as I fix my crew cab ill be taking this truck apart for my 4x4 (body parts and stuff)
This is a experiment ill be driving for maybe a month tops!
so long term problems don't matter to this ride
any info will do
Thanks
Joe
Old Jul 18, 2007 | 02:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
Heating the springs will mess up geometry as well as the springs. Don't do it.
Old Jul 18, 2007 | 10:24 PM
Franklin2's Avatar
Franklin2
If you are going to do a homemade drop, you can cut a coil off the springs. If you go just a little bit, you might get away with the alignment, but that's usually not enough for the "look". For the really dropped look, you need to get lowering beams or change the whole frontend out.
Old Jul 19, 2007 | 08:22 AM
Big_kid's Avatar
Big_kid
I wouldn't do it. I'd be concerned with tempering the spring and making it brittle. If it's a temporary ride, why bother? Put that time & effort into your other truck, that's the one you want to drive anyway.
Old Jul 23, 2007 | 11:56 AM
mudgepondexpress's Avatar
mudgepondexpress
I drove for years on a set of "torched" springs. It is fairly easy to do but it is also easy to go to far! First thing is to figure out how much you want to go down then mock up some frame supports so they stop the drop when you get to the desired height. Then start at the bottom of the spring and start heating a coil...roughly half a coil until it start to collapse. while you are doing this watch your frame / support relationship..it changes fast! When it starts to drop stop your heating until it settles.
The other trick is you need the tires to slide or you won't see the true results until you drive it due to tire/ground friction. I use 2 pieces of formica with grease between them. jack the wheel up, place the two pieces under the tire and lower it again. If you push down on the bumper you will see the tire slide across the ground.
To drop it roughly 2 inches you will collapse 1 full coil. They do not get brittle, they actually get spongy. Some people reach in the side and torch just one side of 2 or 3 coils...that makes them bow out and work horribly.
Kenny
Old Jul 23, 2007 | 12:40 PM
joewaldner's Avatar
joewaldner
lol now we're talking .... someone who's actually done it....... will dropping it 2 inches mess up the allignment ? and what else do I have to watch out for?
Old Jul 23, 2007 | 12:50 PM
mudgepondexpress
Yes it will change the alignment! The only thing easily adjustable is the toe so you should check it before you drop and after. If it has changed, put it back to the pre drop measurement. It also changes chamber but this is a good thing. The F150 has a ton of postive chamber stock and eats up the outside of the tires, dropping it 2 inches (well, my drop was 2 inches) will give you negative chamber and you are looking for roughly 1 degree negative chamber. If you acheive this the tires will last 2 to 3 times longer than they used to.
Kenny
greasemanicure
71
Jun 13, 2019 09:21 PM
JoeVR
1983 - 2012 Ranger & B-Series
Mar 23, 2014 01:05 PM
mnkeeking
May 4, 2012 08:18 PM
jtindale
15
Dec 21, 2011 10:49 PM
fordblue_ca
Jan 27, 2001 07:26 PM
