dead off the bottom
Old Jul 18, 2007 | 10:02 AM
Moyerboy's Avatar
Moyerboy
dead off the bottom
I have a 94 ranger with a 3.0L and it is a dead pig it stalls up to 2 times wihen its cold and then when u get on it its dead until you get up to the 2500 RPM range then she runs better but after I put a new EGR valve it ran worse and the check engine light comes on even more now can any one help me
Old Jul 18, 2007 | 10:14 AM
asmith68's Avatar
asmith68
Sounds like timing to me, could also be a vacuum leak.
Old Jul 18, 2007 | 10:36 AM
Moyerboy's Avatar
Moyerboy
weve checked all the vacums and it only doe sthe stall when you first start it in the morning the rest of the day its fine
Old Jul 18, 2007 | 11:09 AM
quicklook2's Avatar
quicklook2
what are the codes?
Old Jul 18, 2007 | 11:18 AM
cddz's Avatar
cddz
Another thing you may want to check is your fuel pressure when this is happening. also you need to reset the KAM by disconnecting the battery over night or for at least an hour.
Old Jul 18, 2007 | 03:58 PM
Moyerboy's Avatar
Moyerboy
there are no codes it just comes on and stays on for most of the driving trip and is off when i start ther truck at a latr time but i hasnt been coming on as much since i only run back and forth to school which is lik 10 minutes
AngeliasDad
33
Jun 1, 2011 09:44 PM
david_351
2004 - 2008 F150
Dec 23, 2008 10:39 AM
Rizzle
Electrical Systems/Wiring
Oct 20, 2005 07:53 PM
JD717
Oct 6, 2005 05:48 PM
jonny_blue
Sep 26, 2005 08:56 PM
