Modular V10 (6.8l)
Squeak?
Old Jul 18, 2007 | 09:35 AM
RAGaz's Avatar
RAGaz
Squeak?
I know I'm probably being picky, but I have a very slight squeak in my '05 F350 (25K miles) that sounds like it could be coming from the suspension. It squeaks when I hit even small bumps in the road, it's really bad on the dirt forest service roads. My '03 V10 did it as well and I was never able to pin point the source. Has anyone else run across this? Is there a quick & easy solution?
Old Jul 18, 2007 | 09:46 AM
boxcar1974's Avatar
boxcar1974
On my 03' it is the sway bar bushings. Others have reported front spring bushings. It is easy to remove the sway bar to see if that is your squeek. The Ford bushing are not that good.
On edit I see you have a 05' so I guess it is not the leaf spring in your case.
Old Jul 18, 2007 | 02:32 PM
hydro_37's Avatar
hydro_37
I just spray a good lubricant on my bushings when they start to squeak and after several different times spraying them they seem to have soaked in the lube and quit squeaking. Not sure how it will affect bushing life but it is a 3 year old truck now and no problems.
Old Jul 18, 2007 | 06:45 PM
wfof250v10's Avatar
wfof250v10
thats what mine did around 20K and I crawled under with sprayed all the bushings, linkages, etc......squeeks went away after a couple of miles.
