quick connects....
Old Jul 18, 2007 | 08:47 AM
indebt's Avatar
indebt
quick connects....
did you guys cut the QD line on the outlet of the fuel pump after the hutch mod? Since its the last part of the system that has that should I remove to get a tighter connection or just leave it alone?
Old Jul 18, 2007 | 09:07 AM
F250_'s Avatar
F250_
You can leave this one alone. The fuel line quick connect fittings designed by Ford actually work well under pressure. It is when the line is under vacuum conditions (like when sucking fuel from the tank) that they suck in air. That's why the instructions from the ITP kit only addresses the fittings on top of the tank and on the suction side of the pump.
Old Jul 18, 2007 | 09:47 AM
indebt's Avatar
indebt
thanks, that does it then!
Old Jul 18, 2007 | 09:53 AM
F250_'s Avatar
F250_
You're welcome. Congrats on getting a really great mod done. i wish I had done mine much sooner, because I still can't get over how much quicker the fillup time is at the station compared to before. Also, I really like the extra throttle response I've found since putting in my fuel lift pump with the in-tanks.
